Yeah. Steel wool trick FTW. Some more expensive cans have baffles and stuff in them, the cheaper ones are just hollow. Idea is to provide as much scrubbing and surface area in the can to catch the oil droplets. I just bought a 6 pack of pot scrubbers, pulled them out (they sort of stretch out) and then used a screwdriver to pack them through the drain hole. I think I used about 3 or 4 of them, packed quite tight in there. Took 30 mins or so, but I guess it depends on your drain hole size! A hollow can won't do shit really; it doesn't provide any resistance.
Be careful though- the scrubbers will slice your fingers up it you go pulling too hard on em. Voice of experiences :P
regarding smoke/seals - check you have it plumbed correctly. It should not effect that side of things at all. It just goes "in line" with the PCV valve piping. I can't see why that would make the system pressurise.
Looks like I have a mildly dangerous project to do later, lol.
The only thing I can think of is if the PCV valve leaks with boost forcing against it (ie doesn't seal), there could be issues. All I know is my old turbo smoked like crazy with it connected & didn't with it off. And I can't see how anyone could possibly plumb this catch can in wrong.
Take the PCV valve out, clean it up a bit and give it a little BJ, see what happens. You can clean them up a little with (JETWRECK BRAND) Brake cleaner. (He'll get the reference).
Seems normal to have a little air pass through them when pressurised, of the 3 that I have blown through. Just not a lot of air.
I did that a while back & I could suck air thru and it 'clicked' as the ball/valve shut when I blew & I couldn't get any air to pass thru. But I also tried out a boost gauge once & couldn't get the needle to budge, not even 1psi, lol. So I don't think my lung test is very valid as 15+ psi is vastly different to my 0.2psi ;) .
Just fitted Dale's Piano Brace. Awesome stuff.
Now just have to finish installing the wideband so I can put the dash back together.
I can't believe how long the 'piano' reference has hung around, lol.
Bahahaha!
Lol @ piano! I'm glad I wrapped your brace up properly now.
Smartarse. ;)
Disagree.
I had one of those little (300ml?), hollow Just Jap catch cans (cylinder shape) between my PVC and plenum on the NM35.
Every 10,000kms is was about a 20% full of oil.
I had it in next to the brake fluid so maybe having the top of the catch can as the highest point between the PCV and plenum return made a difference?
I haven't seem catch cans that are situated lower in the line work very well.
Is there a picture on here or someone can provide to show where they have hooked it up to. I was looking at installing one and not too sure where to start. I am going to install it in where the master cylinder is.
Disagree.
Why can't we all agree on something, lol? My catch can is one like yours. Maybe there's something to your theory about altitude...
That's a good spot Josh :)
Excuse the eclectic mix of coloured hoses - I just use what I have available to hand - function over form.
Edited by Commsman
That is exactly where I had mine although the holes were a little different and I used 3/8 rubber hose with rubber grommets in the holes.
Nice and tidy :)
You'll also notice that I tried experimenting with a second catch can next to the battery (passenger side breather > catch can > Intake) which did absolutely nothing.
Edited by iamhe77
Nice installs. You mounted the can with the inlet/outlet at the bottom or do the hoses turn up once thru into the brake enclosure?
So, nothing collected in passenger side? Maybe something to do with the altitude, lol.
There'd be nearly no vacuum where it's plumbed into the intake (was yours plumbed in between filter & turbo?) as the only restriction is the filter itself - maybe a couple of inches of mercury? Gravity may help out on mine as it's mounted much lower. I tipped half a cup of sludge out of it yesterday.
Thanks very much guys. Leon using that blue works in my favour as I can see where the hose goes.
Too easy Josh. Cam's is more stealth; going under everything & in black.
Disagree.
Disagree all you want, still doesn't make you right. :P
The only thing that has going for it, is that the can would be colder, not being situated n the engine bay proper. Thus it's effect on condensation of the vapour would be greater. Still doesn't mean you were catching everything going through the system. There are pics of mine, but it sits in a place that nm35s have intake piping, you no use.
Hey dudes I'm new here thought I would give this thread a crack!
I have a s2 c34 2001 model. Has 100,000km on it so time to start replacing some worn bits. Got it stock with a blitz rice cooker muffler but I have done the following:
New shifter boot (Was leaking. Easy job!)
EBC yellow stuff front brake pads (so much better than stock and great pedal feel!)
New fuel filter genuine
New oil filter genuine
Royal purple oil (loves it!)
New gear oils (front, transfer,gearbox and rear diff)
New ps fluid
Boost controller
K&N air filter element
R34 NA wheels (had r32 wheels on there when I got it lol I know random as)
Big detail (guy who owned it lived near dirt a lot and didn't like washing it lol )
Ku31 tyres fitted
Wheel alignment
After all that the car is a lot better than when I got it! Got a genuine timing belt kit (belt, cam seals, crank seal,idler bearing and tensionor) and water pump cheap so will be doing that next. Any tricks and tips for the neo?
Next plans: coilovers, adjustable arms, rear swaybar and some form of different wheels
Also anyone know the best place to get adjustable rear camber arms for the s2 4wd with hicas?
New ps fluid
Boost controller
Ku31 tyres fitted
Wheel alignment
Have a look through this:
http://www.skylinesaustralia.com/forums/topic/73824-adj-camshaft-pulley-new-cam-belt/
Did my timing belt and water pump today.
Wouldve finished yesterday if I believed the how tos and didnt overtension the belt....
would appreciate a timing light that works well on the white loop down the back of the head to save pulling the intake apart (temporarily) just to get to #1 coil.
Was putting the 25G back together after frontal repairs. Did not get finished caus a bloody great python slithered into the garage.
I did a runner. LOL
Not quite overnight parts from Japan, but my new toys arrived today thanks to Mr Streeter:
Grill went on straight away, unusual for me I know:
post-34363-0-92262000-1346396883_thumb.jpg post-34363-0-81516800-1346396912_thumb.jpg post-34363-0-51231400-1346396938_thumb.jpg
Was pleasantly surprised when it arrived that it was ready to go straight on. I'd read a post by Aaron in a previous thread that they used to come without the mounting holes. Unless that was a different, similar looking one.
I like the look of the grill, but I'm not totally happy with the mesh. Thinking it might look better with black mesh.
Looked at the instructions for the EVC, but it'll probably be a couple of weeks before that goes in, I've got a fair bit on over the next couple of weekends.
