I'm liking the 'whale shark' look on Moby. Maybe black mesh would look better, or whiter?
How'd you go with the wideband - get it in & working yet Ryan?
Black mesh would look better (as would 30mm spacers on your wheels :P)
Missing the need for HKS stuff :(
Oh, you NEED HKS stuff. Ask Alex. He has what you need. You just might have to remove it from his car first! :P
Wouldn't mind trying the spacers but not sure if I could get away with them on the front. Might see if I can borrow a set locally.
Yeah it's kind of silver Leon. Funny, they ask you to quote your paint code so they paint it for you, which is great, but they don't mention the mesh, just supply silver. Weird. I might see if I can track down some black to try.
I got the wideband in and working - kind of. Thanks for your help Leon.
In frustration I ran the wire back from the fuel pump, got it all working, but I just haven't been able to get the car up so I can put the sensor in. The bung is welded in now, I just need to jack it up and connect the sensor, which I'd prefer to do when there's light out and/or I can get access to the hoist or pit.
Scissor jacks suck. With any luck I've just found a proper jack for home, which would be much more convenient. Annoying when tools let you down and a 5 minute job becomes an hour...
That ^ is the story of my life, but often exceeds an hour (day?), lol.
For any work at the front of the car I use ramps, but I need long planks (old stair treads actually) to lay on top so the gradient is less steep & the front clears.
My car is high enough now for me to probably do an oil change with it on the ground :P I was under it the other day taking out the guard liners so I could swap the head lights around - so much room! I used to use a trolly jack and jack stands though. Fairly quick and painless operation, I used to struggle with ramps because the front was too low.
Huh? I remember your car being on ARX springs... Looked like it was on stilts!
Not quite overnight parts from Japan, but my new toys arrived today thanks to Mr Streeter:
Grill went on straight away, unusual for me I know:
post-34363-0-92262000-1346396883_thumb.jpg post-34363-0-81516800-1346396912_thumb.jpg post-34363-0-51231400-1346396938_thumb.jpg
Was pleasantly surprised when it arrived that it was ready to go straight on. I'd read a post by Aaron in a previous thread that they used to come without the mounting holes. Unless that was a different, similar looking one.
I like the look of the grill, but I'm not totally happy with the mesh. Thinking it might look better with black mesh.
Looked at the instructions for the EVC, but it'll probably be a couple of weeks before that goes in, I've got a fair bit on over the next couple of weekends.
Nah it's the same one. But did come with mounting holes that were in the wrong spot. I guess they got one too many complaints and stopped pre drilling lol! Looks great! I think it's one of the nicer grills out there for the pokemon
Cheers Aaron.
Got black mesh in it now. No photos, too dark now. But it does look much better.
Wideband in and calibrated. Hard to get an idea of exactly where it sits but seems to be 14.8-15 on light cruise, and anywhere up to about 9 at full throttle.
Now I can fit the FPR with a bit more peace of mind, knowing I can verify with the wideband.
Booked in to make up the 3" intake in a couple of weeks. Should be a good thing!
AFRs sound about right. 3" intake will be a good thing, but brace youself for the AFM cut when you go WOT :P.
Dyno run1: car wasn't boosting. turned out cat was blocked: causing almost 9psi of backpressure
Dyno run 2: a week or so later, with "modified" cat and new actuators, was making decent numbers, but massive exhaust leak from rear turbo
Dyno run today: new gaskets, everything tight and perfect: popped one of my turbos.
Looking at replacements/alternatives now: has running R33 N1s, but considering HKS GTSS, as I have a pair available from a trusted source, and they're all but brand new and well priced...
Oh no i feel your pain thats what i had got them of ebay for $1000 and one let go,i have nielly got enough money for my singel turbo conversion :yes: at lest if you blow one of them i have a spair i can sell you :yucky:
im going to have a set of tomei dump pipes for sale soon if your interested
Just had the exhaust done from tip to tail by Andrew at AM Performance; and absolutely fantastic job and quick turn around.
To go into a little more detail;
Purchased a 2nd hand Freeway Dolphin cat-back exhaust via Jesse Streeter and already had a Scotty Dump Pipe waiting to go on. Talked to Andrew about getting a midpipe sorted and perhaps installing the whole lot for us while he was at it.
Dropped the car off on Saturday arvo/night (around 5:30pm) and picked it up almost exactly 24hrs later, though he did have it ready to go at 11am. Frickin awesome stuff! An absolute pleasure to deal with and will definitely go back to him with any new work, even though he around an hour away from home, he's just that good.
I'll try to get a pic or two up of the finished product but I have to say that it sounds mean as. Seems to have better response too...
All in all very happy with the end result :woot:
So you're the M35 he ditched me to work on? :P
Glad you're happy with it! He does cracking work, great bloke to deal with.
Haha, seems that way. Is it recommended to get on a Dyno after getting the exhaust sorted? Andrew mentioned doing so but I was under the impression that a Dyno wouldnt be of any real use apart from getting some numbers as the ECU cant be modified or tuned to take the exhaust into account and it has the ability to learn...
Is that right or am I way off?
You're right. I think if you could tune your ECU it'd be a good idea, but since you can't don't worry about it.
Might be worth looking at an eManage or F-con at some point?
The piggy back systems arent on the cards at this point; the car's only meant to be a Daily for the missus but I might be able to play around with it every now and again and throw some goodies on. See what happens I guess
Correct, no use going to a DYNO unless you have a method of tuning.
However, reset your ECU so you can more easily feel the difference made by the exhaust, rather than waiting for it to adjust slowly as it learns.
Edited by Commsman
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
