Correct, no use going to a DYNO unless you have a method of tuning.
However, reset your ECU so you can more easily feel the difference made by the exhaust, rather than waiting for it to adjust slowly as it learns.
The 25G was driven out of the garage yesterday. It has all its bits on. I am going to call him Joseph. Silver guards, white bonnet, S2 rad support and when I get time a red rear bar.
Have completed all the paperwork to pursue the matter for costs, it goes through QCAT here in sunny Qld, which has replaced the Small Claims Court. When and IF I get a settlement I will have it "refinished". I think that is newspeak for respray.
Thanks to all the guys who helped This Forum has saved me heaps over the years.
Cheers, Hugh
Cheers, Hugh
This post is useless with pics!
Show us Joseph!
Cheers, Hugh
Anytime. Glad to hear it's out of the garage.
On Friday, I decided to remove the foglights mounted on the bumper as they are just slowly getting stonechipped and I never use them.
After removing the front bar, I was shocked to see that my front reo bar was damaged. This was damaged when I got reversed into, and was not replaced by the repairer. I have taken photo's and will contact JustCar and see what is the go from here.
Anyhoo, I have always been interested in where the AC get's it's outside temp reading from but could never find it. Well I found it while the front bar was off didn't I and I moved it ! But to where you ask ? no ? ok fine....
Well I want to know what the air temp is my engine is sucking in so I placed it right next to the air filter.
The only thing I can think of as a downside is that the Auto AC setting will be going off that sensor, but i even have plans to get more of these temp sensors, wire them all in earthed to a rotating or multipole switch and then I can choose the sensor and push the button to see the readout :D All will be sweeeeeet
Oh and I painted my grill black. Ugly grille still ugly, just black :D
You can see the damaged reo bar on drivers side, and i also brightened the air temp sensor location
New position of air temp sensor
Tadaa
Looks good mate ^^
Put in new platinum plugs and hardrace adjustable castor rods. More response with the plugs and much better steering response with the new castor rods. Will be doing new rack ends and tie rod ends soon along with slip on lock spacers as the stagea can't turn for shit. Already smoothed off the steering knuckle knob which made a big difference with lock but the rack is out if travel so these spacers will help. Cv joint angle looks ok still while spinning which is my biggest concern.
Thank you Davey. CV angle is a concern of mine too with the amount of k's I do. I recently just put in bcpr's and tapped em to .8mm car runs so crisp. Will look into platinums though for next change. You are spot on about the hardrace adj. castor rods. They are indeed the next thing I am purchasing handling wise. I unfortunately know nothing about "smoothed off the steering knuckle knob" so I will look into this. Do you have any more info on this and the slip on lock spacers etc ? I will go searching now :D
coppers give better spark than platinum
iridiums come close to copper but with the service life of platinum
also, that black grille looks pretty good
i might have to get some plastiwrap and do mine similar to that
i love how even the reo is yellow lol
Oops I ment the lock stops. Grind them off the steering knuckle. I am taking a guess and got the slip on lock spacers from GKtec to suit Nissan. Should be the same as silvias/skylines
I changed from .8 to 1.1 may have some difference?
First oil change since new turbo went on, and fresh oil in both diffs.
Diff oils came out very clean, but both magnetic drain plugs had a decent amount of filings; possibly not cleaned at last interval. :unsure:
Wats new in my stagea life. Well just got home from picking up my second stagea. The auto my fiancé will be driving. So those in adelaide if u see her don't hesitate to wave. And I have just purchased a manual one. Pics will be up when she gets a clean. And then I'll be looking into wheels for the new girl :)
Yea it's a s2 rs4s. :) and yea looking around but thinking more akin lines of 9" rather the. 9.5" but I'll see Wat I can afford at the time. As not going cheap
18x9.5 +12 for the manual stagea (assuming c34)
/wheel dimension dilemmas
Seems to be the perfect fit for a stagea!
Has anyone had problems with these size wheels and hitting the front inner guards? (When lowered)
a set of rota wheels will set you back around $1k + $500ish for tyres in that size for some cheapies
in a 9 you'd want something like a +10 but anything around there will sit well
I run 18x9 GTR wheels with 235/35/18 tyres and they lightly rub the inner guard liner at full lock. Not enough to worry about though
your an auto are you not duncan, so you'd be pretty flush on the rear but inset on the front, going from a +30 (stock gtr offset) to +12 would probably make it flush and stop the rubbing
in other news, i just ordered a cusco rear strut brace and a mate should be picking up my new front sway bar for me soon :)
Then i'll only have to wait till mid november to drive my car again, getting pretty bored with just driving the gf's R31
Spent an hour or three pull off bits to get down to the knock sensor in the V of the block in my ARX. Computer attached to car to diagnose why it was running very rich and had retarded timimg came back with - "faulty knock sensor". Was assured by mechanic it was definitely faulty not a loose or otherwise bad connection.
Have a look at the attachment and you will see a nest made of firewall material and chewed conductors. The mouse trap is artistic licence.
Thanks to Scott I found my way down to the problem and now know a bit more about how it is put together. Hope not to have any left over parts when it goes back together tomorrow - once I repair the cable.
Edited by Old Gregg
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
