Made a resilient mount for my bc solenoid valve.
Tried a foam backing first, still could hear the hammering resonating through my bracket.
Silent now....
Also painted my master cylinder stopper Nissan under bonnet white (aka rustkill rattle can satin white).
I want the engine bay to look like everything was there from the beginning.
I grabbed a GKtech r33 spec one that someone mentioned was in a clearance sale....
Cooling mod received today - thanks Scott!
Will try and get it in this weekend. Radiator and hoses are due Monday, but will take a couple of weeks to get around to fitting. Once the radiator is here I also want to see if we can make up a custom fan shroud to run thermos before the radiator goes in.
Back in QLD at last, awesome Stagea fun times to be had now
Fitted my gktech BMC stopper
Billet shift knob
And Cusco strut brace :-)
Still to go: white line sway bar, ebc and magnetic drain plug
Waiting to see how badly scored the bores are, then it's on to ordering new pistons rods and incidentals.
Does anyone know if R33 GTR front strut braces fit a C34 S1 RSFour?
Also looks like I'll be getting the PFC EL commander to replace the oldschool, scratched unit I have moulded behing the gear stick: I may actually be able to read it... ;) between nasty scratched lens, and the heat from the trans tunnel, the LCD unit is Very hard to read on the fly...
Billet shift knob
Welcome back to QLD! you must be pumped to be back with the Stagea. If you had a simple bleed valve, as I did - you will love how much better an EBC is. Which one did you get ? Also did you buy F+R swaybars ? Will be interesting to hear more feedback on them.
Can't help with much, but if you want to - try some 2000 wet n dry / scotch brite, then autosol or toothpaste on rag/buffing wheel. You may be surprised about getting rid of alot of scratches from the LCD
So happy to be back
Currently running a turbotech v2 and will be setting up the blitz SBC when I can be bothered to do the wiring lol
Only front sway bar (gtr) item but it came with the HD links which will replace my rattleing stock ones
Not sure how much of an upgrade it will be over the stock item but I'll report back once its in
Yeah: thought about that, but realistically, the heat from the transmission making the screen go dark is the major issue: thinking I'll just bite the bullet and go LED. Plus, it's nice to have new stuff!
In the meantime, I'm getting the front windows tinted and repainting the wheels and brakes so the whole car will look pretty fresh when it finally hits the tarmac again...
Not exciting but I washed the front half of the 25G. We are on tank water here , and as it has not rained for nearly four months the tanks are low.
If I had washed the whole car I would not have been able to have a shower tonite.
Finally went round to Supershit and picked up a cheap mobile phone holder to mount the Informeter to the vent. It's been out of the car for over a year, so it's about time it went to good use.
I think there are a few guys with them mounted this way. Bracket cost about $10, I think it should work well. Should be useful with the upcoming changes to the cooling system and intake, to measure the before and after.
post-34363-0-08008100-1352368848_thumb.jpg post-34363-0-75945600-1352368960_thumb.jpg
And while I was taking pictures, I don't think I ever posted any of the EVC setup...
So I mounted the display over between the cluster and the pop up screen:
Under the bonnet, I'm hoping that it's pretty subtle:
With the stepper motor mounted under the new battery cover:
post-34363-0-76641800-1352369238_thumb.jpg post-34363-0-67864400-1352369282_thumb.jpg
The extra wiring you can see next to the stepper motor is for the F-con intake temp and MAP sensors. The FPR will be mounted on the left, next to the stepper motor.
Saturday morning I'm going down to fit Scotty's cooling mod, then I'll hopefully leave the car with AM Performance next weekend to finish the intake while I'm in Melbourne.
Still no intake?
Still no cooling mod?
:P
Hey, I got the cooling mod Tuesday! I didn't have any silicone otherwise it'd be in already! :nyaanyaa:
Intake is waiting for Andrew to get an opening, he's pretty busy at the moment.
BTW Scotty, PM me your phone number, might try and drop by when I'm in Melbourne if you're about.
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
