I'm rebuilding a VQ25det at the moment, it seems Nissan cant sell me any big end rod bearings... Wat?
I wonder if VQ35 ones will fit, anyone know a way to find out? I guess I will have to measure the stock rods and compare them somehow...
I didn't do anything....
But Scotty saved me by sourcing and fitting a new rad this afternoon, after mine decided it no longer wanted to keep the water on the inside... Bleeding the cooling system is a biatch...
Good to finally meet Aaron as well after all these years..
Thanks again mate!!! :cheers:
the bearing grades will be very minor differences in clearance...probably 1/10th of 20thou. If you are not buying nissan they will only have one grade. If you are buying nissan you could carefully measure everything....or just pick the middle grade and go with that
How did it go on the way home Nick? I should have sold you that spare coolant mod, it would have been quicker to fit that than bleed your engine...
Ran like a dream thanks Scott. Temp gauge sat where it is supposed to the whole way home. Also drove across all possible bumps to give it all a good shake for bubble movements..
Swapped out the battery, and as expected the little window was showing bright red... New battery has restored normal starting..
Ha good to finally meet you too mate! Glad Scott got it all sorted!
Just fitted the HKS sensors for the F-con. Nissan was nice enough to leave me a decent spot to drill and tap the IAT sensor into the pipe the BOV mounts to, and two holes blanked off that I can mount the MAP sensor to. Just need to plumb the MAP sensor in now, thinking directly to the plenum rather than try and tap another thing in where the factory sensors are.
Also dropped the oil, replaced with fresh 300V and a Greddy filter. Guess I've got one more fill with 300V, 1L left over :/
Best measure of intake pressure is in the end of the plenum. Same place Nissan put the barb for the OEM sensor.
Right I'm with you now, the tiny hose on the end. Although there's also a factory sensor in the BOV pipe too.
Went on a little cruise with the v35/36 club of WA.. theyve adopted m35's into the club as theres not many in the scene. Met my first m35 other than mine today as NickM91 came along for the cruise .. had a great time and shared lots of info.. :cheers:
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
