rear pads in, hopefully gotten rid of the wear issue i have been having, right hand pins/sliders were seized, so relubed that up and seems to be working better now. could actually slide by hand when i was done.
Got the HDI FMIC on yesterday, not too bad. I need to sort some broken/ missing/ torn out undertray bolts asap. I have the NUR catback exhaust and Scotty's dump and front pipe on it already. I think the next thing is Dales induction tube and a high flow turbo. But which one ? What I want is a quick road car not a race car I can nurse around the street, and the numbers are less important than the feel and driveability. But I'd love to try before I buy. :unsure:
I have the kits that Commsman uses to tweak the computer but haven't had a chance to solder them up. (Before anyone jumps on this I have been working overseas from 2/12/12 till yesterday.) (And I have not had the car tuned yet. :yucky: )
Hi Leigh. Give me a while & I may have a hi-flow you can try. But I wouldn't rush to change the standard turbo out, unless it's had it.
+1 with Leaon about the turbo.
If you do the Banjo mod and keep good oil in your car the stock turbo can perform very well and is hard to beat for off the line drivability.
OK Thanks for the offer Leon and all the great help, assistance and advice you have given me so far. I love my sound system/media system. The cruise is absolutely necessary and even the wheel switches started lighting up since we did the slimline fan in the FMIC install! Go figure! :wacko: As it gets quicker it gets harder to set the cruise to avoid it hunting but that's expected at some level as the turbo spools. Just went down town through a 50 zone and watched the car burble up a rise at 900 rpm/50 kph in top gear! Gotta love that... When I said that I wanted to try before I buy ... I meant experience what other turbos respond like, not necessarily from a drivers seat. A seat of pants from a back seat where I can see the rpm, roadspeed and feel the response should give me a clear idea if it is too laggy for my taste. This car will never be raced, if it does go down a drag strip that will be the exception rather than the rule. The problem is trying to find the balance between driveability and power. As I do not want an extreme car some of the more prominent peoples experience is irrelevant. It is probably true that the people I really want to connect to do not post overly much. So if you are out there and have a moderate highflow and induction solution with great driveability and reasonable performance at a realistic price please respond! My standard turbo is OK atm so I am not under any pressure at this time. :closedeyes:
i'm pretty sure someone is rebuilding the turbo basically to stock spec's might have to ask Jet_Wreck about it.........
hi Andy long time no speak, what's the banjo mod?
That's where you drill out the turbo oil feed line at the banjo bolt. It is a really small hole that can get blocked by grunge, especially if service intervals were 'stretched' when back in the mother land.
It is widely believed that Aaron's turbo failed due to this oil line being blocked.
Looks like he thinks Craig's advice is irrelevant, it's the reason I never posted a response anyway.
cheers Leon. :)
Replaced my broken cibie light glass.
Cleaned up ok Josh?
Looks like he wants something he can drop in without tuning etc, and doesn't want the power some guys are making. I get that.
I don't think Craigs' recent thoughts are common knowledge, ie he wouldn't know if irrelevant or not. And, as it turns out, is very relevant.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
