rear pads in, hopefully gotten rid of the wear issue i have been having, right hand pins/sliders were seized, so relubed that up and seems to be working better now. could actually slide by hand when i was done.
Got the HDI FMIC on yesterday, not too bad. I need to sort some broken/ missing/ torn out undertray bolts asap. I have the NUR catback exhaust and Scotty's dump and front pipe on it already. I think the next thing is Dales induction tube and a high flow turbo. But which one ? What I want is a quick road car not a race car I can nurse around the street, and the numbers are less important than the feel and driveability. But I'd love to try before I buy. :unsure:
I have the kits that Commsman uses to tweak the computer but haven't had a chance to solder them up. (Before anyone jumps on this I have been working overseas from 2/12/12 till yesterday.) (And I have not had the car tuned yet. :yucky: )
Hi Leigh. Give me a while & I may have a hi-flow you can try. But I wouldn't rush to change the standard turbo out, unless it's had it.
+1 with Leaon about the turbo.
If you do the Banjo mod and keep good oil in your car the stock turbo can perform very well and is hard to beat for off the line drivability.
OK Thanks for the offer Leon and all the great help, assistance and advice you have given me so far. I love my sound system/media system. The cruise is absolutely necessary and even the wheel switches started lighting up since we did the slimline fan in the FMIC install! Go figure! :wacko: As it gets quicker it gets harder to set the cruise to avoid it hunting but that's expected at some level as the turbo spools. Just went down town through a 50 zone and watched the car burble up a rise at 900 rpm/50 kph in top gear! Gotta love that... When I said that I wanted to try before I buy ... I meant experience what other turbos respond like, not necessarily from a drivers seat. A seat of pants from a back seat where I can see the rpm, roadspeed and feel the response should give me a clear idea if it is too laggy for my taste. This car will never be raced, if it does go down a drag strip that will be the exception rather than the rule. The problem is trying to find the balance between driveability and power. As I do not want an extreme car some of the more prominent peoples experience is irrelevant. It is probably true that the people I really want to connect to do not post overly much. So if you are out there and have a moderate highflow and induction solution with great driveability and reasonable performance at a realistic price please respond! My standard turbo is OK atm so I am not under any pressure at this time. :closedeyes:
i'm pretty sure someone is rebuilding the turbo basically to stock spec's might have to ask Jet_Wreck about it.........
hi Andy long time no speak, what's the banjo mod?
That's where you drill out the turbo oil feed line at the banjo bolt. It is a really small hole that can get blocked by grunge, especially if service intervals were 'stretched' when back in the mother land.
It is widely believed that Aaron's turbo failed due to this oil line being blocked.
Looks like he thinks Craig's advice is irrelevant, it's the reason I never posted a response anyway.
cheers Leon. :)
Replaced my broken cibie light glass.
Cleaned up ok Josh?
Looks like he wants something he can drop in without tuning etc, and doesn't want the power some guys are making. I get that.
I don't think Craigs' recent thoughts are common knowledge, ie he wouldn't know if irrelevant or not. And, as it turns out, is very relevant.
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 馃ぃ And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 馃お
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
