projects Posted April 16, 2013 Share Posted April 16, 2013 The cam tensioners take a fair while to fill with pressure once re-assembled, that would have been the noise you heard. Nothing to worry about unless it doesn't go away. The workshop manual says to rev it to 3k and hold it for 5 minutes to bleed the tensioners. The valve gear has solid buckets, some are shimmed and some aren't. If it's hard to start, try a new battery first. If you still have issues, is there an engine light up? Most of the faults will throw a code. This sounds like it might be the cause. i've just noticed that i've got a slight oil leak so am having to track that first and sort it out. found one of the 22 bolts for the front cover one wasnt tightened all the way. so will re check them all again and clean it up hopefully sort that out. and then bleed the tensioners cause 3k for 5 min with a oil leak might not be a good idea. as for the battery when i connect up a jumper pack i still have the same issue. but jumper leads to a vehicle the issue is still there just not as bad. there was a timing fault that came back before the chain but thought that was cause of the chain needing replacement. might be a good idea to run a diagnostic again? Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6817391 Share on other sites More sharing options...
pipster11 Posted April 16, 2013 Share Posted April 16, 2013 This sounds like it might be the cause. i've just noticed that i've got a slight oil leak so am having to track that first and sort it out. found one of the 22 bolts for the front cover one wasnt tightened all the way. so will re check them all again and clean it up hopefully sort that out. and then bleed the tensioners cause 3k for 5 min with a oil leak might not be a good idea. as for the battery when i connect up a jumper pack i still have the same issue. but jumper leads to a vehicle the issue is still there just not as bad. there was a timing fault that came back before the chain but thought that was cause of the chain needing replacement. might be a good idea to run a diagnostic again? clearing the ecu faults and cleaning and the throttle re-learning procedure probably wouldn't hurt too Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6817608 Share on other sites More sharing options...
projects Posted April 16, 2013 Share Posted April 16, 2013 (edited) thanks for all the help. have read that sometimes the passengers cas fault code doesnt come up sometimes? also how many liters of oil does a engine normally take? EDIT: sorry done a google search and it lead me back to SAU with the figure 5lts. Edited April 16, 2013 by projects Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6817704 Share on other sites More sharing options...
Commsman Posted April 16, 2013 Share Posted April 16, 2013 Yep, 5L when filter changed. Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6817784 Share on other sites More sharing options...
ironpaw Posted April 16, 2013 Share Posted April 16, 2013 In any case, my current one doesn't suit my driving preference so am looking forward to trying something different once the one on the new engine gives up the ghost. Too laggy? Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6817846 Share on other sites More sharing options...
pomnz Posted April 16, 2013 Share Posted April 16, 2013 Also i'm now having a starting issue which i thought the timing was out from the chain, but with that replaced its still hard to start. I'm wondering if its a faulty sensor or if the starter and everything is drawing to much current from a slightly old battery. Would the ecu or learnt that with the old chain and timing been so far out to drive like that. and now its back to factory it cannot start properly? Hi and welcome to the forum. Have you looked at the intake & plenum for carbon build up? Apparently this is a bit of an issue on the non-turbo stageas due to the direct injection, there was a thread on the v35 section of this site with pictures that showed significant build up after far less KMs than are on yours. I seem to remember someone cleaning it and finding that the car ran a lot smoother and also started on the first crank. Probably worth checking out. Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6817912 Share on other sites More sharing options...
projects Posted April 16, 2013 Share Posted April 16, 2013 Thanks for that, might have to add that to the list of things to look at on the car. Lucky I have access to a acid tank so I might aswell tank them if possible. Will browse the v section now. Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6817957 Share on other sites More sharing options...
scotty nm35 Posted April 16, 2013 Share Posted April 16, 2013 sorry, just realised it was a DD. I wonder if the mechanical fuel pump is on the way out, that would explain the excessive cam chain wear. Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6818030 Share on other sites More sharing options...
M35woah Posted April 16, 2013 Share Posted April 16, 2013 I haz rotardz. Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6818052 Share on other sites More sharing options...
Jezboosted Posted April 18, 2013 Share Posted April 18, 2013 Suspension is working great. Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6820097 Share on other sites More sharing options...
M35woah Posted April 19, 2013 Share Posted April 19, 2013 Dale spec front brace.All I can say is WTFBBQHKS.... combined with swaybars and the bushes the car has awoken. turns in soo sharply.Imagine all the hard parking I can do now xD. Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6821797 Share on other sites More sharing options...
GoldZilla Posted April 19, 2013 Share Posted April 19, 2013 You'll be so much more stable now when you hard park with the wheels turned! Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6821808 Share on other sites More sharing options...
Jetwreck Posted April 19, 2013 Share Posted April 19, 2013 Dale spec front brace. All I can say is WTFBBQHKS.... combined with swaybars and the bushes the car has awoken. turns in soo sharply. Imagine all the hard parking I can do now xD. Make a very nice difference aye!!! Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6821826 Share on other sites More sharing options...
Brick Posted April 19, 2013 Share Posted April 19, 2013 I'm still waiting for Dale to make me one. I'll get one one day Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6821827 Share on other sites More sharing options...
Daleo Posted April 19, 2013 Share Posted April 19, 2013 I'm still waiting for Dale to make me one. I'll get one one day Making some now, apologies to people who've been waiting. Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6821850 Share on other sites More sharing options...
Brick Posted April 19, 2013 Share Posted April 19, 2013 Awesome. Any idea when they will 've good to go? Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6821862 Share on other sites More sharing options...
Daleo Posted April 19, 2013 Share Posted April 19, 2013 I've got 5 in the post on Monday for Chris (Footo) in WA, but after that maybe a week?I'll revive the thread. Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6821866 Share on other sites More sharing options...
Brick Posted April 19, 2013 Share Posted April 19, 2013 (edited) Well this months budget thanks to Jetwreck is ruined., he is a bad influence haha. But I would be 100% to grab one 15th of next month once I'm paid again So not a massive rush but would love one then Edited April 19, 2013 by Brick Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6821868 Share on other sites More sharing options...
richzx Posted April 20, 2013 Share Posted April 20, 2013 I would like one too please Dale. Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6821928 Share on other sites More sharing options...
M35woah Posted April 20, 2013 Share Posted April 20, 2013 Ha, it's wet today and I have to pick my GF from the airport so ganna be super fun! Make a very nice difference aye!!! Everything adds up. All I need now are my shocks and spring and wrap mah rims in some decent rubber and I'll be glued. Well this months budget thanks to Jetwreck is ruined., he is a bad influence haha. But I would be 100% to grab one 15th of next month once I'm paid againSo not a massive rush but would love one then HA! yea he can easily spend all your money! But he's also good at saving you money. I wanted to buy a whole set of bushes he talked me out of it and said just buy caster ones and I'll be sweet. Saved probably $200? Or more. Link to comment https://www.sau.com.au/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page/307/#findComment-6821986 Share on other sites More sharing options...
