There is no solenoid, only a coil for the cam actuation. It is the blue plug on the cover you see. Perhaps you didn't seat the coil properly when you reassembled?
There is a good chance the sensor/sensors are starting to fail, I would change both cam sensors (on the back of the heads) and see how you go.
THANX HKS! I still got more bits to get like tyres for the V35 rims n gotta get the R34 calipers rebuilt. U the best :D.
Can I repay you with BJ's? xD
Care to elaborate the BJ part???
Sumitomo kits are about $30- $50 on Fleabay ;http://www.ebay.com.au/itm/NISSAN-Skyline-Sumitomo-4-Piston-BRAKE-SEAL-REBUILD-KIT-Front-Disc-Brake-Caliper-/400486674567?pt=AU_Car_Parts_Accessories&hash=item5d3eddb087&_uhb=1
When I stripped & rebuilt my Sumitimo's; the seals were so good I ended up re-using them. A bath in some hot, soapy water and they were good to go.
Admittedly, they looked like they'd done very little work.
I'm not sure, I guess theyre Sumitimo's. I havent looked at them in months, They came off a wrecked stagea I bought the manual conversion kit.
My guess is they were an upgrade from the standad front brake set up
im currently trying to source r32 gtr front brakes with no luck. Its like all set have been snapped up lately and people selling them want 4 - 500 just for front.....
. I have r32 gtr brakes on mine and they work well
Fair enough, if you stumble across some 34 brakes you can run those without your shims
Just for reference:
With anything R34 using 14mm bolts and everything else using 12mm bolts (need to have shims for S2 C34's and M35's)
