Yeah I'll look at getting it done when I get back to Darwin! Wheel alignment is made such a huge differences also This afternoon put the new filter in and bolted up the front pipe (still standard from cat back) It's amazing! Throttle response is up! Standard boost gauge is now reading 7 (is this Okies) definately gonna try to make back to willowbank next Wednesday! Also managed to lock my 1 1/2 yeah old daughter in the car :( stupid auto locking! She didn't mind, got in after a little bit! Need to get a second key cut
Haha, thanks mate.
I'll be a bit disappointed when this is done as I'll have nothing to to rib you about, lol.
Oh, I don't know; I could always revise my stance on paint colour in the meantime... :whistling:
Had my varex muffler installed yesterday along with dump pipe back 3 inch 100cell cat. When open fark these things are loud compaired to my old 2jz gte aristo.
. Was it worth the wait, how quiet is it closed.?
haha can you post up a DIY with instructions for others with that issue?
I removed the faded and cracked rain shield/wind deflector thingies. Unfortunately the weather strips under won't clean up OK, I think I'll need to replace them sometime.
1) Go out in wet weather.
2) Wait for dodgy driver to follow closely behind
3) Brake suddenly & get rear ended
4) Boot latch now works*
* Individual results may vary.
Hahaha
Haha I was waiting at a intersection, lady behind thought there was a gap I should of gone for but didnt see the Ute coming. So she went thinking I was going to take a gap, but ended pushing the lower left bumper in a little.
Dont know how but im happy the boot works.
Finally got time to do the exhaust, cust 3" from the cat back, will be doing the dump and front pipe eventually. Also put on an apexi pod filter, dam that thing is loud.
i am intrigued by your ideas & would like to subscribe to your newsletter...
yes very loud. would a mid muffler make it less loud?
Of course, although 'hot dog' mufflers don't do much. You need a 5 inch round body muffler at least, the bigger the better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
