Plan to get it to the strip ASAP but its going to be hard as I'm living in Canberra these days.
The butt Dyno says it's a lot fast than the last unleaded tune, 312RWKW which was good for 12.3@119MPH 1.92 60'
Edited by numleg
Be interested to see 100hp shot of nos straight of the mark would make a huge improvement to allow these big barges to utilise the massive rwkw figures youve described.
E85 proves great for the end result, tho can increase lag from burning cooler.speant gasses dont have the same heat to get the turbine spinning up as easy.
He he we will find out :) I've just been stock pilling a heap of goodies for the c34 including a nos system, for that exact reason,:) as well as e85 and wmi , see how much more the old stock neo will take;)" and the gearbox :(" before the new engine set up goes in
Have not had much time to work on the c34 lately. I've been busy with my mates rs4s and the doing a few little things to the m35. But I did get chance to chuck the new seats in today no more sliding around post-76904-0-08659700-1385039514_thumb.jpg
  • Like 1
Yeah should keep us both snug and comfy I matter which one is driving , now I want a set of seats in the m35 as well!! My work car c34 stag has rs4s seats which are already comfortable
No need for more power to get a faster ET its all about clutch/throttle control off the line.
First time I visited the quarter I had a nice soft/light clutch in the Stagea which was very easy to build a little boost and then slip it off the line @ 6500RPM
I ran 12.35 @ 114MPH 1.69 60' with crappy 245/35/19 rubber and only 277RWKW
I fried that clutch pretty quick though and have been back twice with new clutch, more power, better wheel/tyres yet taken bugger all off the ET. The hard part is effectively launching a car this heavy with a clutch beefy enough to take the abuse.
Yeah I'm running a 2step to help with the off the line thing :) and then nos not for over all power but to increase under the curve to pull the heavy bitch out the hole.
One Blitz Nur Touring cat back shiny pieces of 80mm 304 pipe installed.
So far nice quiet no drone...
Sure the heat generated from some overweight right foot behaviour will change this...
Was a 30 min job thanks to the easy to understand instructions...
Coneeecheeewaaa...
Oh man, I've gotta get at least another muffler on my car now - it seems louder than it was before I had it in for all the work I had done on it recently. Something is holding the boost back too, not sure what exactly that is as yet, but I need to find it and get rid of the restriction. The torque and power curves flat-line and you can feel it struggling when it's running on high boost, but on low boost it doesn't feel as bad.
Sorry Im not familiar with your bus & mods but ...
Has the ecu been remapped since latest mods?
High flow exhaust often leeds to runaway boost pressure and a factory ecu pulling timing out etc...
Is your intake pipe (if rubber) ? Sucking closed?
Factory dump & cat still or?
Nothing as spectacular as the previous posts.
A good while back got a dash mat for the RS4. Fitted like a glove. Later I got a mat from an unmentionable for the 25G. . I finally fitted it today. It is like a soft sock.
Had to use a bucket full of viagra, oops velcro to get it to fit. Looks shit but will protect the dash.
Coneeecheeewaaa...
Yours came with instructions??
Mine has never droned, but it does get much louder over time.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
