Unfortunately the only thing stoping the new Greddy profec EBC being wired in is me Doahh!
Plumbing run & hidden well but fitting the tiny wires threw firewall proved a daunting task for a excaveman and hence that was as far as the coopers sparkling ales got me.
If theres a simple pic for a simple twit please forward.
Will happily post the Fitout & review of this EBC if I get it running.
Ah, sorry, it's reasonably fresh in my mind. I just put a profec bspec 2 in the 180.
Just match the wire colours up, pick up power from the cig lighter or something. The instructions I printed off weren't too bad.
Nothing as spectacular as the previous posts.
A good while back got a dash mat for the RS4. Fitted like a glove. Later I got a mat from an unmentionable for the 25G. . I finally fitted it today. It is like a soft sock.
Had to use a bucket full of viagra, oops velcro to get it to fit. Looks shit but will protect the dash.
Got any idea on the brand/supplier of the dash mat for the RS4?
I need one to keep the glare out of my eyes and don't know where to buy from.
Thanks!
Edited by wookster
Yeah the wiring i think will be ok but nm35 firewall behind battery is proving a task for me oversized hands
Put a coat hanger wire through first. Just don't stick it into the wiring loom.
Under dash is my least favorite part of the car. Usually requires a couple of physio appointments after!!
Put a new radiator in my beast today. It seems to have fixed my heat soak under load on the highway problem.
The coolant I dropped from it was still quite brown even after the mechanic was instructed to flush it after doing the welch plugs.
So I did a reverse flush with the old radiator and got rid of some more crap from the engine.
Installed the new radiator with some small difficulties but all in all not too bad for a mid-range aftermarket one.
Needle didn't move much on my highway test run, hoorah!
Also pulled the wheels off I got with the car, one tyre was down to the canvas :O
Put some ford territory steel wheels on instead, they'll do until I save some more money up
Greddy Profec installed...
The unit is extremely well made. I had the now low (9psi) & high (15psi) settings adjusted in 5 mins. The fact it has alarm overboost warning aswell a limiter setting is peace of mind.now to fiddle with the other options utilising the bar graph screen layout option to get the best ramp up to preset pressures....
Why such a low low boost? These cars run 12 psi from factory.
These cars run an easy 12-14psi on standard boost without a tune....shit you could even bump it up to 18psi and the ecu with more than protect everything without a tune.
P.s. The turbo WILL fail one do regardless of the boost....at 9psi the thing would be a bag if shit!!
Its set at 15psi craig. The 9 psi is purely due to low/high settings requiring to be installed.
The donor turbo to be highflowed is 7 weeks away from Japan threw Import Monster (why did i click send by ship)
Ill be happy to be on the road until that stage.
I thought it would be an even bigger bag of shit parked up broken.
Appreciate the feedback tho.
I highly recommend the new Greddy EBC for anyone in shopping for a boost controller.
I wonder what the difference in the spooling rpm is with a greddy profec (or similar EBC) vs a humble ball and spring valve? I know a $30 valve is a big improvement over just running an open line from the pressure source to the wastegate actuator.
Im currently looking for a lower spooling rpm since I have put on a hypergear hi-flow rebuilt turbo.
When do you expect your turbo to start making usefull boost? Here is my chart achieved using a Mac valve and my G4 Link ecu as electronic boost controller:
You get what you pay for. Take a look at the greddy profec pdf and you will understand the difference in having full control in cabin vs standing under the bonnet winding a bleed valve in and out. The main difference is keeping actuator held closed via the solenoid allowing a faster ramp to the set total instead of bleeding of via ball valve.
The proper (Turbosmart style) ball valves actually work in a similar way as the electronic controller, and they do a great job of holding boost pressure off the actuator until the desired boost is reached.
I still prefer an electronic controller for the simple fact they have an overboost warning, and the ability to run a 4 or 5 port MAC valve.
Looks good Toby. :)
At the moment I am running 9psi max boost. I am trying to improve the turbo response under 3000rpm. Currently it starts to build boost from perhaps 2300 rpm, it can produce the full 9psi by 3000 rpm, but I would like to improve that around 2500 - 2700 rpm band where it sits at highway speeds.
Currently I am using a cheapo turbotech (which btw gummed up and caused some big overboosts, resulting in me replacing the turbo), but with very little preload on the spring. It does help the spool compared to a direct wastegate line, but I cant add any more spring pressure without winding the boost up.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
