LOL! Read that completely wrong. I thought you paid $100 for a set of tyres!! I thought "Do you even grip?".
I got a screw in one once, drove on it for a while just tightened it when it was leaking lots lol.
Hahaha yeah i tightened the offending screw when i jacked it up to put some spare 17" i had sitting around (to match rolling radius') but found that my nuts were too big...
So i'm glad i found some cheap 19" tyres a few months ago.
Finally made a steel cargo barrier for the boot in the stagea (instead of the original leather one) as the wife was going for a bit of a drive with lots of stuff in the back.
For anyone who is interested, the top metal rod of the normal one is 13mm - I used a half inch (12.7mm) solid rod which clipped in just fine, with a 20mm by 20mm steel tube for the bottom, and 3.15mm thick 50mm by 50mm mesh welded between the two for the middle.. :-)
Ian
Well finally had a bit of shed time! Fitted up rs4s rear cradle and 2way lsd, and whiteline rear sway bar , adjustable camber arms front and rear, hicas lock bar , r33 rear brakes and t3 rotors to match front , greddy rear strut brace. Wired in full race ets pro altessa controler as a stand alone unit, got the recaros in and bolted up, slid some nice new wheels under with some substantial 265 rubber on the back , connected and mounted my innovate motorsports lambda meter and put in some jtc n1 coil overs, and put on carbon ganador mirrors
Now just a wheel align and all good , when we get a bit of cool weather ill go and do some more tunning and turn boost up and water/meth injectionpost-76904-0-45997100-1390659802_thumb.jpg
  • Like 1
Now just a wheel align and all good , when we get a bit of cool weather ill go and do some more tunning and turn boost up and water/meth injectionattachicon.gifimage.jpg
Such a shame you didn't get much done... :whistling:
Sounds like it'll be almost a different car! It's looking damn good too.
Nice! Did you find a lock bar that bolted straight up or did you have to do a cut and shut job on one to fit?
Fitment stance style with grip :) 18x10 +10 with a 265 on it very little stretch only -1.5 deg of camber , nice big contact area for grip, only rolled gaurds no pumping or manipulating ! A very happy boy
  • Like 1
My wagon is back in the shop as of this morning to sort out the exhaust (it's almost head-ache inducingly loud), some light-throttle tuning and a few small niggles here and there. Something was causing some restriction somewhere, so hopefully the exhaust sorts it out while still reducing volume. They're sourcing a new muffler from SMB, and apparently an SMB muffler has been used on a 500kW R33 that's still pretty quiet.
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
