Took the tractor for its first visit to the Dyno. I think it did alright with its stock turbo and 3 inch turbo back exhaust :D
">http://7I7CgA0.jpg
Not to shabby, what ecu are you using to tune it?
Good stuff.
So what's next?
Hopefully injectors and new turbo but will have to see how the funds go lol. I also have the classic faulty pressure switch causing the 4wd to come up so will have to deal with that at some stage too
mounted the fcon in the other little glove box thing
">http://yGhQlVt.jpg
  • Like 2
I have the same issue with the pressure switch, such a pain, I wish there was a reasonably priced fix for this
  • Like 1
Car got tuned today with an adaptronic, drives awesome now. The ss1 turbo ran out of puff unfortunately, so thats all we could get from it.
Looks good to me mate.
It may have run out of puff for chasing a higher number, but it would be my choice over a bigger (laggier) turbo any day. Probably faster everywhere bar a drag strip too :), at least where I live - hardly a straight road other than the freeway around here.
  • Like 3
Lucky I'm not in sa then and yes I did leave the windows down
No worries man. I could be wrong anyway
Just for some reason thought I would check it out there .
Obviously it's not that hot this time of year!
Written off due to to expensive to repair
same thing happened to me 2 weeks ago, got payed out friday.
Wife lost it in the hills, hit a oncoming car and went down a embankement through a fence, everyone was ok
thats my stagea ownership over, just going to buy a normal family daily this time...
cheers
darren
Edited by jet_r31
Fitted some tan leather 350z seat into my m35 today bolted up perfectly. Passenger side is a bit to low but will fit some spacers tomorrow. All the electrics and airbags are plug n play aswell :-D
  • Like 1
Now that is good to know.
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
