^^ Needs to drive an Evo. lol.
Or a Volvo XC90... 5 cylinder slung sideways between the front wheels aint great... Especially when there is room for an in-line 6.... :yes:
I threw in my 2 R32 GTR Seats, a Whiteline rear swaybar and cleaned her up real nice. Still need to source some 14mm tubing to upgrade the brakes. That's next on the list.
Cut out and cleaned up the rust from the front doors, what a mission. Passanger side chased all the way down to the body line, so a lot of bare metal that needed renewing. Then when I went and got the paint made up it is completely different, looks more champagne than white. Next it is going to JLM for the front shafts to be replaced. Just need to wait for the merc to come back from the panel beaters before dropping of the beast.
  • Like 1
Wired up and installed my Ganador mirrors this morning. And also got around to polishing up the HKS exhaust which I will get put in this week. Now to find someone to put in the coilovers.
Finally reunited with mine last Tuesday after 2 months off the road.
Now sporting a rebuilt transmission from Kewish. Never realised how much I enjoyed my until I had to drive a 2" raised Prado for a couple of months (good car, but that handling :()
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
    • I had my car for over 10 years and done around few thousand miles but never changed the oil. thinking of changing it.   what brand and viscocity would you put in ? people seem to use redline shockproof in the diff   on  contraty seen others using atf dexron 2 or 3 so wanted to check. is it 1 liter?
