Cut out the front bumper and made a stainless steel bracket for the number plate that bolts in the factory position. Also rested on the eylids to see how they look before i get them painted pearl white.
  • Like 2
Noticed a knock in the front end since i installed the superpro 33mm solid front sway bar. Inspected it today and noticed a gap of 6mm (3mm each side) between the fixed rib and the support bush. So i made up 2 dense rubber spacers to fill the gap and stop the knocking. While i was at it i regreased the rear whiteline sway bar bushes as there was excessive creaking from the rear end. Another day another thing fixed. Next will be the passenger side inner driveshaft boot.
This weekend efforts on the wagon
1. Fitted the front half of my Alcon brake upgrade.
2. Drove it to WSID and ran a 12.2 (a PB).
3. Split the heater core on the way home and turned my girlfriends shoes a lovely shade of glycol green.
  • Like 2
Whilst vaccuming out the rear seat of the Stag over the weekend I was shocked to discover that under all the wrappers, leaves, stones, nuts, random bits of plastic, crayons and multitude of other crap that had built up over the past couple of years of being the famliy hauler...there is actually carpet back there. Who woulda thunk it. Somehow, it's still beige, and it's remarkably clean.
  • Like 1
After waiting for a VSS from Nissan for 3 weeks this beast is back on the road. And it was nice to see the previous owner change all the fluids except the transfer case in 18 years. It was very brown to say the least. Felt good to drive it again.
Edited by CaSilvia
1. Paddle shifter from V35 GT-8. Took of the leather wrap underneath is aluminium, I sanded it and polished. I can post a wiring diagram for anyone wants to do it.
2. Strutbar from Aliexpress.
3. Clock from a G35 through Ebay.
  • Like 1
That looks way better then the after market setup. And price looks possibly better. How is the feel?
And yes show us your wiring diagram :)
No. That one on Ebay is for a later model V36-37, and its hard work to modify. V35 GT-8 look like this and its a direct fit. Just remove the steering wheel and line up the holes. You will also need the top and bottom steering shroud if you want to return your car back to way it was.
  • Like 1
Any noticeable improvement over stock for the brace? Also price on the g35 strut brace?
Have a look at the front suspension, notice the strut isn't actually a part of the front end geometry or hub like the 33/34 skyline, it just provides downforce through the lower bush. Hence why the strutbrace makes no difference.
If you want to tighten the front end you need to brace the compression arm as Nissan did with the series 2 V35's (Dale's brace or OX motorsport), and use the Superpro poly compression bush.
  • Like 1
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
