Fark, no good; hopefully it's fallen against a closed valve, otherwise you're in trouble. I'm assuming this happened with the upper plenum removed?
If you know which port it went down, and you still can't reach it; removing the lower plenum may allow you better access.
sorry, wrong wording.
no, in front down onto the pulleys and belts.
engine still unopened.
looked for a solid 45 mins with a torch.
not under the car or on the underside cover.
still nowhere to be seen.
hopefully won't drop or jump up into the pulleys when its going.
yep, magnet definitely on my shopping list
Edited by conan7772
I dropped a nut (steady on...) in the engine bay of my Commodore a couple of years ago while I had the intake manifold off and the valley exposed. No idea where it went but the car still hasn't died. WHY WON'T IT DIE? GAAAAHHHHH!!!
Car back on hoist for hopefully the last time for the handbrake cable and a few small things.
Noise from the clutch gone. Seems to be a tiny noise around the cat but i will be replacing the exhaust from the dump back. Now that the auto is gone i can get something that will sit much closer to the body (less scrape yay!!)
Umm picture of Drive Shaft is all i can offer today.
Handbrake is mounted and almost finished but i didn't get a picture as the car was up on the hoist.
So really on the home stretch now. The mechanic has an S13 he is getting off defect for a customer and i can live without the M35 for another day so i'm hoping to pick it up tomorrow / Wednesday/
Stay tuned
  • Like 4
Just picked up the M35. (picture inserted for joy!!)
The mechanic has given me a link to the build on their website so i shall share
http://rdmechanicalshop.com/2015/12/22/m35manual/
Car seems to be running rich and is in desperate need of a tune. Once the holidays are over i'll get it in to have the emanage tune looked at asap.
Enjoy.
  • Like 6
Nice of the workshop to put up all the details. I reckon Scotty has already started collecting the parts. Lol;)
I'm sure Scotty already had most of the parts ready to go over a year ago :P
I think he is neck deep in ECU / Turbo stuff atm which hopefully will save me some frustration after the xmas holidays :)
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
