Successfully fitted the Greddy Floating Valve BOV which completely eliminates compressor surge and engine shudder.
Also the ECU no longer hesitates and dumps fuel.
Had a bit of trouble fitting the adapter flange as Nissan put the BOV mount right in the internal corner of the intake and it hits the raised collar where the rubber joiner abuts to.
Both the straight and perpendicular adapters have the same problem so just cut out some to clear it.
Perpendicular adapter will not work with the VQ25DET- puts the vent in wrong position.
Well worth the experiment.
Hmm that one will face the recirc vent at 45 degress up or down off horizontal - not ideal
Also the orifice looks small..
Remember the Greddy FV is a 40mm valve- almost twice the diameter of the Turbosmart Kompact which is 22mm.
So you need an adapter with a 40mm orifice to make the most out of it.
My understanding now for shudder with the VQ25DET is most aftermarket BOVs will not release enough air to deal with the slow closing electronic throttle.
Different story if you have cable..
So a bigger valve orifice and more tunable BOV solves the problem.
Fit Apexi GT reserve tank tonight with mot ul MoCool. just like Greddy radiator breath tank, but Apexi one could store more coolant (could store over 600ml radiator)
Edited by YangLIU
It would be ideal if you could bleed coolant up from the rear bleed point into this header tank; then bleeding the system would be essentially automatic.
Even better would be another line leading away from the low point of the tank, to the bottom radiator hose and use it as a fully fledged swirl pot system.
correct! that's what Greddy radiator breath tank do.
but for mine, the Apexi one, the bottom return line is connecting with heater hose outlet (it should be same as bottom of radiator hose). there is only one line on top which is to stock radiator top with zero pressure radiator cap.
next stage is using T piece replace stock air bleed port on heater hose inlet (i ordered some tools but they are on the way). then make a line from stock air bleed port with radiator top line together. that would make air bleeding be automatic.
Edited by YangLIU
So i finally decided to fit the rear leather seats and tan interior. I found that included in what i bought was a ARX option for rear middle seat seatbelt (photos attached). So after a full day all is finally installed but the passenger side seatbelt that was missing. I will need to keep the dark grey until i source another.
  • Like 1
Decided to drive to work Monday...
This is how i got home :P
lost hydraulic's in the clutch near work so i wasn't game to try and limp it home. No loss of fluid and the pedal would still return to the normal position... it was just the pressure point that went basically to the floor.
Have since had it checked by my mechanic who couldnt for the life of him replicate the issue. When i drove it the next day it was back to normal... My mechanic still gave everything the once over and adjusted a few things and so far zero issues.
Made me scratch my head tho...
Got a Innovate o2 sensor and looking at installing it onto my M35 and replacing the standard sensor with the simulated narrowband signal.
I've been under the car and the o2 sensor seems to be in an awkward spot. Is there a trick to remove them or do i need to take the dump pipe off
Brick managed to get a socket and extension on his whilst in situ; maybe pick his brains about this.
Here's how I got mine out: http://www.sau.com.au/forums/topic/459839-m35-dump-pipe-diy-install/
You can see the bung in the front pipe between the front flange and the flex which I will be using for my Innovate SCG-1.
Blitz front mount in today. Modified the supplied brackets and fitted slimline fan, like for the HDI kit so no cutting up the reo bar.
attachicon.gif2016-01-14 12.39.02.jpgattachicon.gif2016-01-14 12.44.42.jpgattachicon.gif2016-01-14 14.42.05.jpg
Bought from JustJAP?
Wont be long until someone comments on the orientation of the tranny cooler.....been there
Yeah, I see you had yours like mine but moved it sideways and into the guard. I thought airflow would be more important. Lots of conflicting views on orientation on the intergoogles. There was plenty of pressure when I last pumped out the old fluid so not too concerned about an airlock. You've got me worried I'm going to blow up my tranny now! :unsure:
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
