So there was a write up to the changes to the stagea model and the reasons behind why they relocated the springs the way they have.
It went something along the lines that the ability to separate springs to the shocks was to allow the cargo compartment not to be hindered by higher strut towers and the ability to displace the load under stress. I may be wrong in my understanding but would it also mean the design of a shock and spring system wouldn't allow enough rebound or loading of the compartment?
When I bought my MCA I thought (incorrectly) that all M35 coilover kits converted the rear to a proper coilover and also that MCA is a well know/respected brand that make quality products and wouldn't sell something dangerous and/or of inferior quality. Along with reaperblitz I thought the change in suspension was to make room for larger compartment not due to load sharing, after all OEM springs are generally quite a lot larger in diameter than aftermarket coilovers hence would require a large shock tower which would take space away from the rear compartment.
Been trying to find all these failed shock mounts on MCA equiped M35's. No luck yet. I did find this though: http://www.sau.com.au/forums/topic/440310-coilover-issue/Both ARX, one with stock suspension, one with aftermarket, both look like the bolts pulled out rather than a problem with compression forces. One due to incorrect adjustment of the shock and one due to loose mounting nuts by the sound of it. You can also see the damper adjuster in one pic exposed to the elements and covered in road grime. If you pull away the interior trim you will see a very strong, reinforced, well engineered C pillar which by chance is what the shock mount forces are applied to. I'll go with an expert, say like someone who builds suspension for a living rather than speculation of what might happen. I'm sure Mr Nissan knew what he was doing but if they got it right from the factory then why would we bother modifying our cars at all. On another note you can specify what springs you want at no extra cost with MCA and don't have to change the large spring again which is a PITA. If you are happy with your BCs, awesome but don't bash the MCAs just because you reckon.
Not bashing at all; there's no question about Josh's product, nor his knowledge.
However; regardless of how well reinforced you might think the shock mount is; I don't believe it was ever designed to support the entire corner of the car on that tiny little sheetmetal cup bolted to the bodywork.
Not speculation; fact.
"I don't believe" = fact? Interesting.
Show me the evidence.
A shock mount is not designed to hold weight its sole purpose is to control the spring. The spring on the other hand does hold the weight of the corner of car
I think i quoted wrong person anyhoo
Edited by stripey
Yeah, semantics; wrote it in a hurry, and thought about it later.
Still not fit for purpose; otherwise Nissan would've just put the whole lot there.
Every strut top I've ever seen or worked with has a hell of a lot more surface area to distribute the load; this arrangement does nothing of the sort. Instead, it localises the entire corner weight of the vehicle on a tiny unsupported piece of sheetmetal spotwelded over a void in the body.
There is absolutely no benefit or performance advantage in combining the spring and shock into one position in this instance; and avoiding using the specifically designed and reinforced spring perch is just an exercise in simplifying his parts bin because he now doesn't need to have custom wound mini-block springs as per OEM.
He can just use his off the shelf small diameter coilover spec springs to maximise his profit.
I stand by my comment, but you are free to do whatever you choose.
Just out of clarity (until I can find the actual reason/ information) m35 rwd is different suspension than the m35 4wd yes?
But the chassis is pretty much the same minus the subframe?
M35 shares its front suspension with the Z33 and V35; the rear suspension and subframe is identical between NM35 and M35
http://www.nissan-global.com/EN/NEWS/2001/_STORY/011016-01.html
Suspension: Featuring a new multi-link rear suspension designed specifically for wagon application
The new Stagea employs four wheel multi-link suspension and realizes superior handling, stability and ride comfort.
Its rear suspension is a newly developed multi-link rear suspension that has the coil springs mounted separately from the shock absorbers and lowers the upper attachment position of the shock absorbers by 270 mm compared with the suspension on the previous model. As a result, this dedicated wagon suspension minimizes intrusions into the luggage area.
Ripple-control shock absorbers are used to isolate the transmission of minute vibrations from the road surface for improved tire-road contact.
*Still can't find the type of multi link system explanation
http://nissan.epcdata.ru/stagea/nm35/6839-vq25det/trans/431/
Edited by Reaperblitz
Thanks for clearing that up Daleo. Slightly off topic. Why would they sell different kits to cater for the 4wd compared to the rwd? Added weight of attEsa system?
they sell different kit as the front suspension is slightly different in the front ie the way the coil over is mounted and its style as it has the front drive shafts in the way of where the lower mounts are
Fair enough. Only time will tell. Just trying to support local and hoping that people don't confuse opinion with fact when deciding on their purchase. All good.
  • Like 1
I've only heard fantastic things about his product; everyone raves about them, and also Josh's product support and knowledge. I have absolutely no axe to grind with MCA at all.
That's why I'm completely mystified by the choice to mount them this way.
TBH; I hope they never have any kind of failure, no customer deserves that, and Josh certainly doesn't either.
This is more than just here mate. This was all mentioned to josh on facebook with concerns and links to the fail as he was developing. Not taking away what he offers what so ever as his profuct has been proven in time attack for years. Im this application this is a big weak point unless the m35 owner sends his/her car to an engineer to strengthen the area in question. 99% of owners wont as this cost plus suspension cost will outweigh other products on the market. And this is not from someone against his product as numerous times i have said i will be keen on MCA blues once i wait to see if current owners running MCAs have this mount cracking/failing in which it eventually will as it has happrned running the BC coilovers set up.
Agree. The shock mount is not designed to take the full weight of the rear.
Different car and setup; In my trucking days there were plenty of people using coilovers on the standard Shock mounts in conjunction with 4 links. Some swore it was fine, but seeing a few fail showed me otherwise.
G35 and 350z with purdy adjustable arms and a Datto 1600 all deleting the factory spring to run a true coilover and they all run more of a shock tower rather than having the mount incorporated into the base of the c pillar. Just sayin'. I wish I had found these damper adjuster extensions (so you don't need to remove the trim) earlier in my research so I could have got away with a smaller access hole in the already weak, flimsy mount. :P
post-135423-0-58039900-1454538431_thumb.jpgpost-135423-0-59756200-1454538450_thumb.jpgpost-135423-0-41492600-1454538471_thumb.jpgpost-135423-0-51704400-1454538833_thumb.jpg
Just looked at the difference. The spring sits on the platform that attaches to the rear end of the brake hub. The modified version uses an adjustable brace? Wouldn't that need to be certified as you're changing the design engineering of the suspension? I.e there's no downward support for where it used to sit?
Just curious- Please entertain the thought process in this
Gives more accurate toe adjustment rather than slotting the subframe.
Thought this was pretty cool if you want to keep the separate spring and shock.
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
