Gives more accurate toe adjustment rather than slotting the subframe.
Thought this was pretty cool if you want to keep the separate spring and shock.
Yup that one works out much better. Maintaining the oem points but allowing adjustability.
To compare which works better (coil over vs oem) the next is to find what the oem spring sits below.. chassis support rail etc
Just filled upon pump 98! Petrol is cheap today! But still thought e85 would be cheaper!? &&0){for(var>
hell id go e85 thats cheaper than 98 here still $1.38 :( ..... but i dont know how a product that only has 15% actual fuel how much is ethanol per barrel
Edited by stripey
Exhaust done and dusted.
Amazing job. Really happy with how it turned out. Sits much more snug against the car which was what i was really hoping for :)
Sounds great. Not loud or droney and not much cabin noise (we did do a good job with insulation when i swapped the centre console when the manual was added).
On too the next job!!! :)
Edited by Beregron
  • Like 5
This is nice man!
Do you have a build thread?
Put my m35 on a dyno today.
165awkw with a dump pipe back 3"exhaust.
Pretty happy with those numbers i think!
Going to go back after getting Scotty's dump pipe and see what kind of difference it actually makes. Everyone say's it makes a big difference, so we'll find out!
^Nice job! Looks awesome! Was it an exhaust shop or the same place that did your manual conversion?
Its the bloke who owns the shed next to the place that did my manual conversion. He does custom fabrication.
oh FFS, i'd finally settled on an MCA suspension because I couldn't replicate stock height with the BC's and then you all go and confuse the issue with your 'opinions' and stuff. WTF is this, a forum?
So in summary, going stock and replacing my shocks with OEM shocks will cost like 1200 (front and back) so they're out, BC's are out because they're too low at the back, MCA's are out because they're potentially unsafe and I need to have the car registered in VIC so it's going through the pits.
there's gotta be an easier way...
Get a set of nismos
<script pagespeed_no_defer="">(function(){var g=this,h=function(b,d){var a=b.split("."),c=g;a[0]in c||!c.execScript||c.execScript("var "+a[0]);for(var e;a.length&&(e=a.shift());)a.length||void 0===d?c[e]?c=c[e]:c=c[e]={}:c[e]=d};var l=function(b){var d=b.length;if(0=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/ngx_pagespeed_beacon','http://www.sau.com.au/forums/index.php?s=d9d7d5f9aae700dcf581ad86f47d27a0&app=forums&module=ajax§ion=topics&do=quote&t=348629&p=7679168&md5check=7effc82b1ab70c8da717535c12f6830d&isRte=1,6YgIICLrb3,true,false,1FH37t1LSRI');</script>
Turned out alright.&&0){for(var>
That's a familiar looking colour.... :thumbsup:
  • Like 1
Are all the shocks dodgy? If not then just replace the unroadworthy ones with "good" second hand ones and then put the MCAs on after you get roadworthy.
They sell spring platforms or spacers to raise the springs for bCs don't they?
I think it's just having everyone's best interests at heart. Can always resell..
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
