josh how much did they charge you for labour on all the bushing mate? Looking at getting all mine done to. Did you run with OEM ones or superpro or the like? Will feel amazing to drive now mate I bet.
I'll send you a message via Facebook regarding price mate.
But yeah all super pro or whiteline depending on the bushes. It does feel amazing. Just need coilovers now and it will have full handling upgrades.
  • Like 2
Taking her in tomorrow for full fluid change, since the car didn't come with service records gonna go ahead and change oil, tranny fluid, diff fluid, and brake fluid
Wondering if anyone might have some insight to a small electrical issue, every so often there seems to be a small power surge causing all the lights to dim. There is a clicking sound when it happens which sounds like a capacitor discharging
Check the simple things first, battery terminals were my undoing last Thursday night in the Stagea when my car would crank over but not start. Was after midnight and the car was in a fairly safe spot, so I got a lift home and tackled it the next day.
Installed a Transgo kit in my M35 today.
Bit of a messy job but found a good tutorial and took my time and got it done.
See how this goes with the paddle shifters.
can you post a link to the tutorial mate?
Here you go.
Not Stagea but same gearbox.
Mine was same at the 5 ball channel casting and also used the white springs where this guy didn't.
Everything else was the same.
http://www.titantalk.com/forums/titan-faq-how-area/107187-transgo-shift-kit-install-how.html
  • Like 1
Sounds like the ATTESA relay clicking, the pump draws a fair amount of current which can draw the voltage down if the battery is weak. How often is it happening? You might want to look at replacing the pressure accumulator if its happening a lot.
I went and replaced the tiny battery that came with my car with an optima coiled cell AGM battery. No voltage dips now, though the relay still clicks a bit.
Ive been thinking of the shit kit , this however looks a lot more involved than when I shimmed my old Soarer's trans.
Nice to see another red one. :thumbsup:
Now do first a big service, and then starts to build.
exhaust system, intercooler, suspension and more
and, of course, look for Axis body kit :thumbsup:
- Key light has started flashing on the dash, which a quick search tells me is a dying remote battery. Life = over.
- Just bought a full exhaust from a 370Z with 55,000km on it for a massive outlay of $50. I know most of it won't fit without...massaging...but it's a heck of a lot cheaper than $400+ for just a replacement Y-pipe and I have a tame welder I can employ. Now I just have to get it all down to Hawkes Bay from Auckland and convince my wife that it's really only prudent to replace the rear half of the system too.
- Ended up replacing the tyres with some Michelin Primacy 3STs of the same size (215/55 R17). Man they kick seven shades of Shinola out of the old Dunlop Enasaves. So grip, much tyre, wow.
- About to head out on another 600km road trip, weighed down by the everything, including a 7-foot ladder and interior door inside the cabin. I have a page-long list of items to take and I'm confident I can make it all fit, the car hasn't let me down yet.
So, all maintenance stuff really but a change is as good as a rest.
Edited by Hertz Donut
  • Like 1
Flushed the trans over the weekend, ohhh back to smooth shifts.
Installed a trans cooler, managed to pop a pin hole in one of the pipes! :O , brazed and all good.
Flushed attesa pump , and then managed to strip/round the filler plug on the transfer case >_< , whoever done it up last time is an asshat. Gonna hunt a new one down Saturday.
Ordered hub rings for the new wheels , got a slight vibration under load from the rear, hope they sort it out.
Edited by malialipali
nice when the next day when you bought your car must use a tow trucks
maf broken :angry:
new now was not an expensive 99€ = 149AUD
always put a spare maf in glove box, that's the bible for M35 user
Edited by YangLIU
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
