josh how much did they charge you for labour on all the bushing mate? Looking at getting all mine done to. Did you run with OEM ones or superpro or the like? Will feel amazing to drive now mate I bet.
I'll send you a message via Facebook regarding price mate.
But yeah all super pro or whiteline depending on the bushes. It does feel amazing. Just need coilovers now and it will have full handling upgrades.
  • Like 2
Taking her in tomorrow for full fluid change, since the car didn't come with service records gonna go ahead and change oil, tranny fluid, diff fluid, and brake fluid
Wondering if anyone might have some insight to a small electrical issue, every so often there seems to be a small power surge causing all the lights to dim. There is a clicking sound when it happens which sounds like a capacitor discharging
Check the simple things first, battery terminals were my undoing last Thursday night in the Stagea when my car would crank over but not start. Was after midnight and the car was in a fairly safe spot, so I got a lift home and tackled it the next day.
Installed a Transgo kit in my M35 today.
Bit of a messy job but found a good tutorial and took my time and got it done.
See how this goes with the paddle shifters.
can you post a link to the tutorial mate?
Here you go.
Not Stagea but same gearbox.
Mine was same at the 5 ball channel casting and also used the white springs where this guy didn't.
Everything else was the same.
http://www.titantalk.com/forums/titan-faq-how-area/107187-transgo-shift-kit-install-how.html
  • Like 1
Sounds like the ATTESA relay clicking, the pump draws a fair amount of current which can draw the voltage down if the battery is weak. How often is it happening? You might want to look at replacing the pressure accumulator if its happening a lot.
I went and replaced the tiny battery that came with my car with an optima coiled cell AGM battery. No voltage dips now, though the relay still clicks a bit.
Ive been thinking of the shit kit , this however looks a lot more involved than when I shimmed my old Soarer's trans.
Nice to see another red one. :thumbsup:
Now do first a big service, and then starts to build.
exhaust system, intercooler, suspension and more
and, of course, look for Axis body kit :thumbsup:
- Key light has started flashing on the dash, which a quick search tells me is a dying remote battery. Life = over.
- Just bought a full exhaust from a 370Z with 55,000km on it for a massive outlay of $50. I know most of it won't fit without...massaging...but it's a heck of a lot cheaper than $400+ for just a replacement Y-pipe and I have a tame welder I can employ. Now I just have to get it all down to Hawkes Bay from Auckland and convince my wife that it's really only prudent to replace the rear half of the system too.
- Ended up replacing the tyres with some Michelin Primacy 3STs of the same size (215/55 R17). Man they kick seven shades of Shinola out of the old Dunlop Enasaves. So grip, much tyre, wow.
- About to head out on another 600km road trip, weighed down by the everything, including a 7-foot ladder and interior door inside the cabin. I have a page-long list of items to take and I'm confident I can make it all fit, the car hasn't let me down yet.
So, all maintenance stuff really but a change is as good as a rest.
Edited by Hertz Donut
  • Like 1
Flushed the trans over the weekend, ohhh back to smooth shifts.
Installed a trans cooler, managed to pop a pin hole in one of the pipes! :O , brazed and all good.
Flushed attesa pump , and then managed to strip/round the filler plug on the transfer case >_< , whoever done it up last time is an asshat. Gonna hunt a new one down Saturday.
Ordered hub rings for the new wheels , got a slight vibration under load from the rear, hope they sort it out.
Edited by malialipali
nice when the next day when you bought your car must use a tow trucks
maf broken :angry:
new now was not an expensive 99€ = 149AUD
always put a spare maf in glove box, that's the bible for M35 user
Edited by YangLIU
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
