C34 is 14mm. Not sure about M35. But you really you have at least a set of spanners if you own a car
Thanks for the info!
Yeah I really do need to get a set, haven't really needed any since I moved to Japan
went ahead and ordered a set from KTC
https://translate.google.com/translate?sl=ja&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.kpt.co.jp%2Fdetail_1.aspx%3FGId%3D14188%26MId%3D161%26FId%3D4%26SId%3D19%26TId%3D68%26FthId%3D194&edit-text=
installed bonnet damper kit today. it is for 350z but could be fitted on m35.
need to drill a hole on each side of fender due to m35 doesn't has it as stock (350z should have the hole as stock)
need 2 medium length bolts and nuts also.
open to stock height
happy with $60 delivery :rolleyes::rolleyes:
Looks like a handly little mod, interesting silicone hose layouts/ colour choice there mate!
that's BOV return hose. my bad i make wrong length when buy it... i re-ordered the customized one for 75cm long to make it beauty.
the hose is reinforced silicone hose, good for intercooler
Edited by YangLIU
Put some fresh front pads in yesterday, and chucked in some new plugs in at the same time.
Spent the first half of today chasing down vacuum leaks -.-
Still running like shit. Feel like I've done something daft somewhere/split something without realizing
Spent the last couple of weekends prototyping a rail delete kit. Covers bolt in place of the rails and have (printed) gaskets to keep the water out.
The covers don't look as good as a full patch job and respray obviously, but I like the fact that its reversible if I ever need to put the rails back on.
Cheers
  • Like 4
Link? Did you get my PM?
Cheers
That's a good job!
Hunting down a intermittent engine light issue. I have narrowed it down to something in the dash or the actual dash. Iv pulled everything out and cleaned jiggled wires. Just a question for those in the know, what is the black box with all the wires that is on the right hand side of the dash hole?
