On 18/12/2019 at 10:40 PM, Cowboy1600 said:
What rails are you running with these?
I think they are S13/14 rails 3 out of 4 bolts lined up I just made a bracket to line up the last bolt
  • 2 months later...
Took out the crap Febest bits tension rod bushes that only lasted 50,000ks. Replaced with oem. Bit expensive but they'll last 150 probably. No more wanders!  And new sway bar links. Oem. No more clunking! Drives nice again.
  • 1 month later...
1 hour ago, Ottdurr said:
When replacing valve cover gaskets I decided to do a full clean and paint of both covers as well as the intake manifold, gonna throw away the plastic engine cover now it's actually a kinda nice looking engine 20200324_152506.thumb.jpg.1cf7234ef72a5062ec8957dc22fba16f.jpg20200329_123928.thumb.jpg.454c0e283455b9da435fbe4dcc09360f.jpg20200329_132216.thumb.jpg.246365a18e1ba3ba08466afb8ba691f5.jpg
Looking good!
  • 4 weeks later...
After a month of toing and froing between the engineer and the road worthy inspectors the ATTKD 6 piston brakes on our  '05 PM35 Axis Autech have been passed (the engineer was awesome, and so are the brakes).  More of a challenge was the rear track - 1565mm which was 5mm over what is allowed.  At the end of the day standard ARX wheels on the back did the trick but looking for something more suitable.
Why was the maximum track 1560? Did the wheels stick out of the guard or was it an arbitrary number?
Wheels are inside the guard - allowable track increase is 25mm and can use the widest track in that model of car - we used 1535 which is a PNM Axis and that gives me a limit of 1560mm.  My wheels are 18x9 with 25 offset - still getting my head around offset but thinking that 18x9 with 30 offset might bring the track in.
Yeah, +30 means it'll sit 5mm inwards compared to +25
  • Like 1
  • 4 weeks later...
so its about time i have written in the topic. my stagea journey started roughly 6 years or so ago when my mum was looking for a new car and had always liked nissans but wanted something practical and she decided on a m35 that she kept for a few years and i had always had a thing for wagons and i had decided a 260rs was what i needed in my life. late last year i put the plan into action and i was able to get a series 2 260rs.
first thing to sort out was the clutch i knew the clutch was on its way out when i bought the car but it didnt worry me all that much as i was planning to change it anyway for increased power. i went with a nismo twin plate and took a couple of days off work to get it sorted. luckily for me im a mechanic at a nissan and we werent all that busy so i was able to come in and use my hoist as i dont think i would have been able to do it on my own on stands.
the car sat on display in the showroom at my dealership for a period of time and while noone really knew what it was it was interesting seeing people wonder why it was in there with all the new cars and reading the plaque i had written that sat beside it
from there  the parts collecting began. i noticed while doing the clutch the front pipe flex joint had torn and was the source of an exhaust leak so that was on the list as i knew i was keeping the car on twins. i ended up getting -9's, hks cam gears and timing belt, genuine waterpump, tentioner, idler cam and crank seals, nismo fuel pump, 950cc injectors, nismo afms, prp r35 coil kit, nismo short and solid shifter with a power fc to run it all at this current stage.
while sadly i dont have any photos of the shifter install it went quite smoothly apart from from getting the selector cup to seat into the gearbox however perseverance and the occasional swear made it go in eventually
the coil kit install was a breeze i decided to change the plugs while i was there and lucky i did the plugs werent old or anything but were a 5 heat range and simply not up to the task of the power i was about to throw at the car. the old coil loom looked tired and was very brittle as expected. i retained the factory igniter box even though it isnt plugged in with the new coil kit as the car had a couple of ground connections running to it
so next is the car is booked in at racepace to have everything fitted and tuned so hopefully ill have a nice looking dyno sheet to post in a week or so
  • Like 1
Tiiiiiidy!!
pic 3 - am I trippin or is that a larger mouthed turbo inlet pipe with tape over ?
On 5/16/2020 at 12:52 AM, RBW49N said:
Have you done that 1000 km yet
Sure have, I found a heap of small fixes that needed to be done like vacuum leaks cam cover oil leaks & stuff but the big one was the 3" exhaust & JDM mufflers were not as well flowing as they needed to be, so after having issues with back pressure I had to get a full custom 3 1/2" system made up with 3 1/2 inch Hi Flow CAT, plus I had the screamer pipe extended & plumbed back into the exhaust so I don't get booked, after an oil change I took it back to Maatouks & had another run on the dyno to make sure all is OK. found out the standard CAS doesn't like anything over 6500rpm so I'm saving up for R35 coils & bracket & a cam angle sensor to go in when I go back for the E85 tune after all this COVID shite... so its still running on great 98 octane at just over 500whp so reliable everyday, very happy & the idle is much lower now & the car shakes a bit at the lights..;)
  • Like 1
  • 2 months later...
I'm still working on wiring my Haltech in. Making some progress but now the thing won't start so (on the stock ECU) I can't test my latest connections!
I did however just purchase a hypergear ATR43 ball bearing turbo... should be here next week ?
    • Dragging some reo behind a ute or trailer will smooth out a dirt road, I've used reo a few times to do unsealed road maintenance when we didn't have any plant available  It's best done when the dirt is wet though, and then you just let it dry out for a day to harden up For wetting the dirt I've used some 44 gal drums in a ute or trailer, and a water pump connected to a hose with a old sprinkler tied to the reo to wet the material down whilst spreading Basically just drive slowly up and down the road a few times dragging a few sheets of reo wired together with the sprinkler wetting it all down as you go
    • I did a motokhana years ago with ??Sydney Sporting Car Club???, it was on a grassy paddock and was heaps of fun, I think it was north west Sydney IIRC The old R33 boat was covered in grass and dirt, but nothing that a good wash and detail didn't fix And thinking back, when SAU did the airstrip run in Goulburn years ago, where the old 33 won highest RWD MPH, the quickest RWD ET on the airstrip, and best paint IIRC (before the runs down the airstrip) the damage to the rear quarters from stones flicking up required them the get a respray  I would definitely do a grass motokhana again in the MX5 Who knows someone that owns a farm with a big empty paddock  Liability these days is a big issue though
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
