Damn..... Is that the reason I have shut arrive that I don't remember buying!!!!
Haha so dangerous...
But, while completely sober, I just scored myself an Emanage Ultimate! :banana:
Despite some sniper at the end who drove the price up from $150, scored it for $355! Came off an R33 and he has an SR20 map, but I should be fine to hook it up. Plus it seems to come with a universal loom! :banana:
I'm very happy with that catch, can't wait to get it hooked up. Just have to get the boost sensor, and should be right to go! Might even try and get it tuned by Cian when I come over for Gymkhana if time allows.
fitted up my 3" bellmouth front dump pipe this arvo, the car pulls sooo much better.
Just gotta get a 3" metal cat and the car will be 3" from the turbo to the rear blast pipes
sooo much less restrictive, and i made it stealthy black :ph34r:
Just fitted my shiny new bc coilovers yesterday, they are a pretty good piece of gear. I did get a bit excited about dropping it though, ended up running about -5 degrees of camber on the rear this resulted in my 350z wheels touching the shock body.fixed it all up today and it feels like a new car. I will say that one of the factory shocks died at the hands of my 4 inch grinder because it wouldn't come out easily - no pain no gain
....And the flames???
they are a bit bigger, turbo spool is alot faster and a lot louder.
but the flames are still there, i nearly melted one of the lads at works R32 front bumper twith them over the weekend!
so he kept up with you :nyaanyaa:lol joke.
dump/front looks great!
found out i have a nice fuel leak from the o-ring seal.
figured out when i lost a quarter of the tank within about a minute and 2kms lol
will need a part number if anyone has it.
cammmm.
Went for a retune on Sat with the MAP sensor and EBC installed...
made an extra 6 awkw @ 19PSI...>_<
The good (or bad) news on the other hand was that Cihan found the LPG was leaning out above 5k rpm...not sure why this was happening. Possibly the weather as the last tune was done in March.
So at least now I won't unknowningly blow my engine up while on gas...:blush:
need bigger jets...guess this will stop me from procrastinating from taking my car back to the gas joint.
Got a price for me for the GTX setup yet Scotty? :whistling: Can't believe I'm such a number chaser...lol
why the GTX?????
arghhhhhhhhhhhhh
you can't compare torque figures from rolling road dynos
its tractive effort which is a factor of wheel size, tyre profile, gear ratios, diff ratios and lots of other stuff
only true way to get a torque reading is on an engine dyno
i know that, but i wanted to see if there was a difference from this time compared to his last tune. i dont care what type of effort it is, if there is an improvement, regardless it will show.
arghhhhhhhhhhhhh
Well considering all these cars use the same gear ratios and diff ratios, and rolling diameters will be very close; it's probably a fair comparison, especially given they're all on the same dyno.
Everyone knows it's just a number; but with identical drivetrains you're comparing apples with apples...
nope, ARX and AXIS have a larger rolling diameter.
also PM35s are different, also as as 2WD and 4WD models of the PM35 (im only talking about models available in australia)
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
