nope, ARX and AXIS have a larger rolling diameter.
also PM35s are different, also as as 2WD and 4WD models of the PM35 (im only talking about models available in australia)
True Ian; but Ironpaw isn't running STD 17's on his anymore, (due to Brembos?) so his Rolling Dia. (depending on tyre profile) will be close to, if not slightly bigger than an AXIS and only around 3% smaller than an AR-X.
Detailed my car today, in anticipation of it's shiny new Aero Bars (which are taking WAAAAAY too long to get painted); my son of rajab it's a sexy bitch when it's shiny!:banana:
Dodo juice Lime Prime is very nice to use on black paint.
Edited by Daleo
dude post up some pics when its done!! i dont think ive seen a black aero model before...........
as for the wheels, wouldnt wheel weight make a difference too, unsprung weight helps with accelleratiion and braking :)
yeh i didnt want to compare with everyone else. i wanted to see if there was any improvement running the extra boost?
5psi for under 100nm(on cihans dyno) isnt worth it imo..
oh n found out my fuel leak wasnt a fuel leak. the sensor is playin up..
Reflection? post-61153-0-26778900-1310425114_thumb.jpg Try not to look at the ugly bloke; post-61153-0-56895300-1310425163_thumb.jpg
With painted skirts;post-61153-0-59531300-1310425226_thumb.jpg Without; post-61153-0-55007600-1310425328_thumb.jpg
Farrrk I forgot how ugly our cars are without the Aero kit...:yucky:
I know, it looks like the dumb smiling kid at the back of the classroom.
Eating paste...
Hey Dale, who painted the tree mural on your bonnet? Not my choice of artwork but it's very realistic.
Door molds?
Yeah, I dunno; I think they tie the wheel colour in better now, as there isn't won't be so much grey.
Going to wait and see; can always get them done later, they're easy to match. KH3 is straight black tinter.
Edited by Daleo
Ok, I just had my old boss translate the Nissan user manual regarding oils, he is Japanese. It said the front and rear diff uses 80w-90 and made NO mention of LSD or non LSD. If its a clutch type LSD as some are thinking the 80w-90 will be fine, this is what we used in our 2 way clutch LSD's, so we cant see it being a problem.
got a dyno sheet?? what torque figures you get??
700-750nm's.....from 3,000 to end buddy!...what was yours again......at 16psi???.....and was it a flat torque curve or a little all over the place?
.....I'm not worried....I am sure I'll crack 800-900nm / 300AWKW's on BP98 at 20-21psi........imagine if I ran E85.
P.S. Don't diss our housings mofo......they are a pretty good stock unit imo.....not as good as the GTX.....and if I had of has the time, tools, money and room I might have gone that way!....who is to say which has more lag? and who is to say what the HP difference is when comparing apples with apples!post-37023-0-31134200-1310446822_thumb.jpg
what are you talking about man, i was asking Jethro lol.
who said im dissing our housings?
your on drugs again arent you?
Edited by Jetwreck
yeh yours is OK......but I am producing the same as you at 105km's and more at 180km's!!!! :P
you sure about that bud?
Looks like you have 140 at 105kph... he has 160 at the same speed, yes?
Or am I reading it wrong??
I'm reading it wrong down the bottom!...lol
Edited by Jetwreck
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
