Did you send them off to have them custom made or did you pick them up from Japan?
Picked them up off yahoo auctions, but they were definitely custom made by/for someone originally!
I wired a Z32 ECU with nistune into my S1 RB25DET stagea today. Its running well with the z32 afm in it but will need a tune when i put the Nismo 555's in it
Well done! Did you cut all the wires off the old plug and solder them on to another plug or did you get a loom extension?
I used a Field harness extender to splice the Z32 ecu in as a piggyback. The stock stagea ecu remains to control the auto
Basically I used that loom i got off you as a guide, but tweaked it a little for the z32 ecu
I think that I could get the z32 ecu to control the auto too, but i can't figure out the corresponding wires between the 2 ecus for the auto. From what i can find on google, the Z32TT uses a re4r03a, the Z32 NA and my car (RWD) both use a RE4R01A
I haven't driven it yet or tested whether the auto is happy with the current configuration, but i reckon i've nailed the hard bit
Finally got my new headlights in; when I got them there was an amber LED array that lit up with the driving lights/squid rings; was pretty sure this breached ADRs so Brad lent me a hand rewiring them up to the blinker; had to wire in the old blinker globe to up the resistance on the circuit to slow down the blinks too. A little hodge-podge, but the end result looks good imho. Hopefully the seals hold up :rofl:
The front of your car looks really good. Glad you got the blinker speed sorted. :thumbsup:
Cheers mate. You were spot on about using the old globe being the easiest way. I threw some bullet connectors onto the spare blue wires you put in & snipped the appropriate connector off the old loom - easy as. Really appreciated your help :thumbsup:
Spent an hour this morning fitting a piece of mesh in the front bar.:blush:
Finished fitting the rear after arguing with the corner clips for quite a while...:rant: Didn't want to damage the old bar, because its going to a new home shortly.
Looks great, was so paranoid about marring the new paint, so was taking it very easy. No scratches; so very pleased with the time taken.
Pics once the mastic has set in the mesh on the front bar & it's fitted.:thumbsup:
cannot wait to see it dale.
oh and for the C34 guy's.....some porn for sale......if only I had a 260rs!!! http://www.importmon...%20114%203%2024
offset is a bit low
Didn't have thse foldy things on the inside of the bumper to hold the mesh in place Dale?
All finished now; looks teh sexy; I keep on wandering out to the garage to look...
It has ten flat tabs spaced around the opening, so I just trimmed slots in the mesh ( I'm using the trusty SAAS "Leb mesh") to fit over them, then I bent the edge of the mesh against the structure of the bar.
I didn't end up cutting the centre spar out of the opening; I think it'll end up being too flimsy & cracking the paint.
I don't have the clips that clamp on to the tabs, so I just glued the mesh in a few places around the opening. It was fairly well fixed in position 'cos I cut the slots pretty tight, just wanted to make sure it stays put.
Pics in the morning; once it's had a bath.
Edited by Daleo
Cheers mate, I'm very pleased, been a long time coming.
Those would be pretty tough on an m35 too; 18x9, +24 offset. The rubber is well past it's used by date tho'.
Was thinking they would look quite good on an m35 as well with the right stance.
theyd look good on an ARX with the extra width compensating for the rub guards crrraaaaaiiigthumbsup.gif
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
