Far Queue. I backed the R30 into the 25G. But I am lucky. The front guard I hit is the one with the rust hole in it and I have a spare guard, so no drama. But I have buggered the R30 rear bar.
Win some, loose some.
I believe I'm expecting a photo of my Stagea in the mail from my good friends at SAPOL. >_<
Ouch... :(
make sure you credit the photographer if you use it anywhere :P
LOL. That, or stock up on protein shake mix, depending on what side you're fighting for.
should i have it before bed??
craig are you going to make it one piece? or have 3 seperate ones like your template?
Don't you want some droop? It forces the wheels to maintain contact with the road when you go over a bump. Having too much droop is bad as this will force the car to raise when cornering too much (dependant on spring rates/shock rates etc.)
Yeah, I should clarify; as little droop as these shocks allow; which is still around 4ish inches.
I agree with you regarding droop helping handling but with the length of these shocks, I was actually more concerned about getting the shock running resonably central in it's stroke to allow a good amount of compression travel without bottoming out the piston assembly.
1 piece.......I will need to test fit on your car as well though to make sure that the one I do fits all.
Edited by Jetwreck
ide be very interested as mine flung off on the freeway some time ago,
i can arrange that. we should just go to the workshop every wednesday night. we have been there pretty much every week for a month lol
I agree....I should be there the following 2 Wednesday nights anyway! Makes it easy to check over things.
I have a spare lying around, but it might be worth waiting to see Craig's "quick release" design.
It won't fit "all" :(
EDIT: fixed thanks Aaron :blush:
Edited by iamhe77
oh as in yours lol you mixed the quotes around i think.
yeh Ill wait for craigs one..if it doesnt im gonna leave it, its alot easier doing a service, a quick release would be nice though
i think a large opening under the sump would be ideal. that way you could leave the rest of the undertray in position
yeh but i cant remember how the stock one is, isnt there a metal bit around the drain "hole"
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
