Rewired towbar plug so that I have no external socket for my trailer; so much neater.
Used flat cable so I can just put it out through the tailgate when I need it, and chuck it in the wheel well when not in use.
A bit boring, but still...
Might fit the new plastic mesh insert in my front bar tomorrow if I don't go riding.
Edited by Daleo
Humour me - by removing the factory radiator (losing the transmission cooler), and then installing a 11"x7-1/2"x3/4" transmission cooler, along with about 800mm of extra hose total, surely the system would need more fluid?
At the moment the dipstick doesn't show any dark fluid on it, which is exactly what is draining from the trans cooler hoses, but appears to have a heap of fluid on it - up to the little s bend in the dipstick.
Is this a problem with topping up from the dipstick?
I've read on the G35 forums that the dipstick is pretty hard to read, but if anyone has any advice I'd like to hear it.
My advice is the dipsticks on our cars are shit.
How much fluid did you put in? Probably only talking about 0.5-1L difference.
Where are you filling it from?
so epic fail with the 'wire cut' mod. must have cut the wrong wire. when i flicked the switch, it dropped a cylinder lol
anyway, installed a western digital live media player in the car. works fine, mounted up front in one of those waste-of-space pocket things. cut out a hole (nice and bodgey) and mounted it in there.
im getting a bit of noise in the picture so ill have to use a sheilded co-ax cable to the back of the car.
anyway, installed a western digital live media player in the car. works fine, mounted up front in one of those waste-of-uuspace pocket things. cut out a hole (nice and bodgey) and mounted it in there.
Lol at cutting the wrong wire...
Are u running the stock firmware on the wdtv? Can it act as a DLNA server?
i upgraded the firmware last week when i got it. yes its WD firmware
i have a DLNA server already, but it will read the files off it. as for it BEING the server, no idea sorry.
I must admit; it took me a while to drag it out of the middle of the harness, they don't want you going after it... Maybe you can market your mod as "Active Cylinder Deactivation" just like a VE Crumblydore...
Don't let it deter you; go again!
I thought the " Awesome" didn't need the snippage anyway?
the awesome becomes more awesomerer with the wire snip :)
i have a factory size toggle switch to go into the 3 spots down on the right, they are all full on my car, so is the 4th one below :(
I used a Stainless steel switch from Jaycar; http://www.jaycar.co...&SUBCATID=978#1
Flush mount, you could put one of these anywhere as they are really low profile. I used one of the factory spots (cos I have no options :whistling: )
I was considering putting the switch on the parking brake but the switch I had wouldn't have worked. Plastic version of what Daleo posted
My plan was to put the switch on the actual pedal so when you pushed it down you would be pushing on the switch.
I ended up putting the switch in the compartment above the glove box
a toggle switch would be better IMO, that way you can leave it in normal mode for when the wifey/dodgey mate drives it.
plus then you dont have to press the brake while holding the button in :P
BTW, because that ECU input is a simple 12V, if you don't want to throw a switch (or push a button) AND press the brake pedal every now and then to keep the MIL light off, you could wire the switch with 12V to the ECU (ie. not from your brake pedal)
Yeah, I know, by the time you flick the switch / press the button you might as well press the brake as well....lol
Edited by Commsman
Well I got my braided lines and wireless reverse camera in the mail yesterday, just waiting on the rear rotors and suspension now.
Not sure if I'm even getting my suspension now. If I don't hear from Street to Track by tomorrow I'll be reporting to the bank to get my money back. Service is terrible, and still waiting for my shocks 3 weeks later. Now they guy won't even respond to emails. Major disappointment.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
