swapped the transmission over yesterday with the 'good one'
big thanks to craig (jetwreck) and andy (andy65b) for their assistance.
the box is pretty much the same, just lacks that overdrive lockup problem which was a massive pain in the ass.
cant wait for the shift kit to go in!!
I hate the way the convertor clutch locks up so early. Previous jap nissans I've had they don't lock until your over about 85km but the m35 seems to lock at about 60km or lower.
Edited by slippylotion
+1.
Around town or anywhere up to about 90km/h, I flick the stick across into 4th; locks out top gear and is generally a bit more responsive.
Doesn't kick down as easily, but I don't find it too much of an issue; much better than constantly shifting up and down all the time, because you can't maintain 70km/h...
I disconnected the torque lockup two years ago, The high stall converter keeps revs up over 2500 when cruising and shoots up to 4k fairly quickly once boost kicks in. I pay the price with less fuel economy though, I still need to fit a switch near the gearstick to lock the converter on long drives.
Speaking of overdrive, is it just me or do these things want to be in 5th gear asap. Cruising at 60kmh in overdrive at 1000rpm seems kinda stupid..
once the box went into lockup, if it was in it long enough it wouldnt come back out of it
and yes they get into 5th quickly, but i find now if i move my foot a little it will kick back no problem.
Got the Cat back on, can actually hear the exhuast note over the induction sound. Gained a few ponies and must have lost 30kg's getting rid of that huge coffin mid muffler.
Front pipe is on next to go on when it arrives.
Hey Ross, what exhaust did you put on? And I like your wheels - car looks great mate.
Picked up my autech on Sunday morning and fitted some 20" rims I had laying around straight away lol. Hopefully getting front pipe, highflow cat and and 3" cat back fitted this week
we want pic's!!! :P
Thats a good time.
1st owner of my stag (CoolPC) ran a best time of 16secs, with catback exhaust k&n pod filter & 10psi
Would love a strip in Sth.Aust to see where it'd be nowadays.
Once the engine is refitted, of course.
$4k is the rebuild price, including engine out/in, tune after run-in, CP piston kit, complete block work (bore/hone, acid bathed, etc), head refresh & new MLS gaskets.
Spent about 3 hours scrubbing away at the double sided tape/foam that the japs must have used for aerials. Unfortunately the previous owners never bothered to remove them so they were pretty much rock hard.
Also debadged the rear end.
Going to get some quotes on how much to spray my wing black/spray my new grille and fix a small dent in the passenger door and most likely respray the bonnet tomorrow. Previous owner did some "touch ups" that most people would refer to as graffiti. I'm hoping I can get away with all of that work for under a grand. No idea though..
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
