Only one way to find out I guess but no more obvious than a Power fc hand controller and cops up here most likely wouldn't know what a boost controller looks like. Haven't ever heard of anyone getting defected for having one either :-/ they usually only check what's under the bonnet
Got a quick road tune in before the Subaru dyno day on Saturday, Cihan isnt very happy tuning the Emanage at 30psi, I guess I will just have to see how it goes. >_<
Craig, is that engine on its way yet? :unsure:
is that still on the unopened 25 scott?
Yep, lol.
It doesnt seem to want to die, its had a hard life the last two years...
lol, any idea if the VQ will run into any issues with the high pressure? i've had a few cooler pipes pop off at 22psi, no big deal, but i'd start getting worried at 30psi on my unopened RB lol.
keen to see the results, thats with the GTX?
Yeh, GTX3071 with 1.06 rear, 45mm external.
Ive had plenty of cooler pipes blow off, I had to modify the throttle body due to the silicone not staying put. All my piping seems fine for now. The bonnet heat guard is shreaded from the air pressure when it lets go. Haha.
The VQ25 runs lower compression, 8.5:1, so I have that on my side. The ethanol has saved my ass though, there is over 6L per minute pumping in, cooling the pistons (hopefully). Its running 10:1 AFR's on boost and he took another degree out just to be sure. Theres at least another 20kw to be made there but we both want the standalone ecu in before its pushed further. Hopefully soon. :cheers:
At the farm at the moment....should finish strapping it for tuesday/ wednesday next week.
Pretty happy with today.
Serviced the Stag, with a new HKS oil filter, Greddy magnetic drain plug and Motul 300v. Have to say the Valvoline came out perfect, as expected. Same gold colour but full of black, if that makes any sense. Got enough Motul for another change now, so I'll see how it goes before I decide if I should change back to the free oil. No difference that I can notice so far.
Started with the upgrades too. Just the front axle for now.
BCs went in, after some adjustment (5cm too short out of the box? WTF?). Followed Dales measurements, and added a bit to get it a bit higher. Feels very stiff but it is also would out to hard from the factory.
DBA 4000 Clubspec rotors and QFM HPX pads went in. So far still bedding in, so dont feel much of a difference yet.
Next week rear BCs, toe arms and brakes go in, then I'll change the lines over to the braided Stoptech lines (which look easy to fit) and refill the brakes with the Motul RBF600.
I have a feeling this car lead a good life in Japan. It seems to have been well maintained, and pulling the pads out today showed half used Nissan pads. I have a feeling it was serviced and driven normally in Japan, no thrashing, which is good!
But they might have been neglected by the previous owners. I think Aaron's was a bit like that.
nope mine was fine. i just had a leak from the oring behind the filter sandwich plate. its good that it was the only leak I ever had..
I think the reference was to some probs you had that could be attributed to less than ideal maintenance before you owned it.
Correct me if I'm wrong, but things like banjo bolt blocked (first turbo failure?) and the sludge you found when you pulled your oil filter/associated mounting hardware off. Chances are a few oil changes might have been missed pinch.gif .
Yesterday I swapped out the painfully noisy Project Mu pads for a set of QFM A1RM on the front of my C34.
The Project Mu pads went straight into my mate's WRX (I have R33 Gts-t brakes)... should be interesting to see if they are as noisy on his car.
What about your tranny? Or was that your own doing? RVO said it was pretty trashed...LOL :whistling:
What the hell is he doing trashing his tranny? Is that what the young kids are calling it now?whistling.gif
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
