looks good Dale, probly be even better if you took those blanking plates out
Nah, it looks pants with them out!:blink: I didn't have them for a week or so, even with mesh covering the spaces; it just didn't look right.
You know what would look great in there... Some spotties. :nyaanyaa:
Yeah yeah, but I think spotties would be a better choice personally... :rolleyes:
I've got the switch & relay parts C/O ironpaw & Prince Skyline, and I'll get my guru mate to sort out the wiring (cos I'm lazy & he owes me a favour) so it'll happen in time.:thumbsup:
Dale will get some spotties when the Damn bar gets on a f*king boat....arrgh
No stress from my end; it takes however long it takes.:cheers:
Hey Dale, I like the look with the support cut out of the front, and checked mine & it looks like the mesh goes right across in one piece (never noticed when I had it out recently).
Can you send me a close up pic of how the bottom cut turned out? I'm concerned that will leave a rough/dodgy edge visible, if I don't have a specialty cutting tool like you used.
I'll take one later today & post it up. When I did the towbar cutout, I rough cut with a hacksaw blade then used a Stanley or scalpel blade to shave the cut smooth, works well; it's very soft plastic. As long as you touch up the paint on the cut edge; it'll be virtually invisible.
Seriously, unless you crawl around on the floor; you can't even see it.thumbsup.gif
Thanks Dale. You did a good job; very neat. Did you colour the edge at all (permanent marker, black paint) or is that the raw colour?
Since mine is silver I may have to find a creative way to camo the edge - if it is visible at all.
It looks like Dale has recessed it a bit, so there wouldn't be anything exposed I wouldn't think.
Might have to do this myself, good work Dale! :thumbsup:
What have I done to my Stagea? Pulled out of the SAUSA track day because I have to go to Sydney for work >_<
But I did order my F con V Pro setup... so all is not lost! :cheers:
So while I pulled out of the track day, next time I go I'll have the shift kit, trans cooler, fuel system and computer in, and will be running E85 :banana:
Really can't be bothered fitting the rear shocks and brakes today though. Two weeks of cold and flu backed up by a sinus infection will do that... :down:
Cheers Guys, I'm getting used to carving up expensive bumper bars now...whistling.gif
There's a ridge about half a mm high from the level of the grille aperture, as I didn't want to carve into the paint, and I've just temporarily used a black marker to cover the line of grey primer that the cut exposed.
The plastic is black, but a paint touch up pen will hide the evidence perfectly. The indent against the mesh is just the way the plastic is moulded, but it's only about 1mm.
Same... Thanks to Cam for all his help so far. Should be a bloody good thing when it's all up and running! Can't wait!
Gave the m35 the 8ltrs of E10 100oct from emptying the tank in the 180SX before it was filled with E85. Just a pity it's raining so I can't really test drive it.
Edited by slippylotion
Changed the oil - was hoping not to have to do it before the turbo kit, but when it was dropped at the workshop I got all embarrassed and felt sorry for herwub.gif
It was so black- now its fresh.
Also did the ancillary belts. Pretty painless really. They were starting to squeak and piss me off.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
