good luck Duncan. Im still waiting on mine since ringlands broke back in early April. Should be ready for run-in any day now.
New forged 87mm CP pistons, complete block overhaul to suit, check of head (previously ported, with tomei cams/springs) etc.
Looking forward to being mobile again :) Its been a while
Nice. I lived in renmark for years and most of my family still does.
Yeah my dad is in Berri. Nice place up there, good to get away from it without too much of a drive.
Front of my Stagea is trashed! So many bugs. Waiting for the sun to go down so I can give it a proper wash..
Andrew I was using the one from down your way, it developed a major leak on the dyno. Not actually sure whose the new one is.
I actually preferred the section from Broke to Wollemi, it is very tight, narrow, and no speed advisory signs to give each corner away ;) The old pac was the most painful, it is signposted 60 from Calga to Berowra nowdays
No doubt the speed limits will keep dropping on these "tourist" roads....enjoy them while you can!
Finally took a photo of my trans cooler for Ryan. Ignore the white spray all over everything - I was mid way through trying to get rid of all of the bugs from the front end of the car and there was plenty of overspray. :rolleyes:
Got the new 3.538 diffs in.....got some good umph now!!!!
My fears of the speedo being out are cured.....speedo and gps are exactly the same differences as they were before.
Just need to get on a dyno to sort out the tune again.
Edited by Jetwreck
gotya, odd though, normally pretty good
and i got an LSD diff :P
also greased up ALL the rubber and poly bushes under the car. its quiet as now
craig, that creaking you heard was the brakes. they do that when cold.
the ass comes out nicely on corners now :)
So the speed signal comes from the wheel sensors? Nice.
Now to see if 4.11's fit. :devil:
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
