info is in the stagea section too but i'll chuck it up here as well
it was a protex - TE926-14
14 means 14mm tie rod, so just measure and if its 14mm ish then this is probably the one for you
they also have a grease nipple on them too, so should last well if they are greased up every so often
Had aluminium radiator and silicon hoses fitted last week. Looks great. Will take pic soon. Car heading to Sydney for Turbos, Injectors, power fc, fuel pump, cam gears fitted and tuned next Saturday :-)
The Mrs modified the front bar on a kerb this arvo. Nothing too bad. Did get a six pack outta it but!
If she comes home with a slab one day, I'll know shes done something bad!
Could this be your opportunity chop out the numberplate piece and a bit of plastic welding when repairing, or is it too far gone?
Fitted the Euro II today, now these are the seats it should have come with from the factory. :yes:
Lordy that looks comfy. A bit more sensible height than the std ones?
1319620594[/url]' post='6080672']
It's really fine, just a touch of the curb on the side. However I did use that as excuse to get the number plate and stone chips sorted out at a later date.
Scott that seat looks great. Much jealous.
Fine choice :yes:
Well that clears the pillar better than the other seat.
Very nice. Not putting one in for the Mrs?
Soon, has to be ordered with a 2-3 month wait.
Well worth the price it seems, they are very comfy seats.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
