Not what I did to my stagea, but more what I did WITH it..
On the way to nightwars (a summer drag racing series), threw sparks all over everyone elses cars, popped a couple cats eyes out of the road and now all I can smell is hot metal... Flexi in the exhaust looks worse for wear and so does the rear tow hook... Might need to raise it. :(
Don't do it!:spank: As an extension to the "Don't buy wheels that fit the car; make the car fit the wheels" ethos; I propose a "Make the road suit your ride height" solution.
You just need to keep frequenting the roads you use; until you've worn a groove them all to suit your ride height, no more clearance issues.
Anything still grinding will eventually be worn away; consider these items "Surplus to requirement" Problem solved.:thumbsup:
You're welcome.:whistling:
Edited by Daleo
ok this is what i found............. so basically its a wait of money.
Posted 27 April 2011 - 02:24 PMsnapback.pngironpaw, on 27 April 2011 - 01:55 PM, said:
Anyreason these won't work for our cars?
http://www.importmon...%20NM35%2014750
review: http://my350z.com/fo...-installed.html
They will not remove our restriction.
Ask Scott when you see him next how well it worked in that regard.
snapback.pngbigkevracer, on 27 April 2011 - 02:13 PM, said:
If I read the old discussions properly though, Mines wouldn't remove the throttle restriction.
I figure we're not going to get a flash that does everything we want, but a flash that removes the speed limiter and throttle restriction and gives us 80-90% of what we want is fine with me. And when I want that remaining 10-20%, I can get an emanage knowing that the two main areas it can't fix are sorted from the flash.
Mines completely remap the entire throttle map... does that mean they remove the restriction? Buggered if I know.
I asked them directly if they remove the restriction below 3000rpm and they replied "we do not", but they did state that they do remap the entire throttle map up to their normal 7100rpm (they will go higher, but issue a warning of "please consider engine safety").
I think your plan of the Gzone + emanage is almost as good as it gets.
came across this whilst searching ebay for other stuff.................... thoughts ???
Throttle Controller
Yes, a waste of money IMO. You'd be better off spending the $350 on real mods to improve the throttle response. Did you see the claim:
Enhances throttle response OR fuel saving of up to 20% ? I suppose 2% is 'up to 20%'....
Edited by Commsman
new o2 sensor today
was hoping to pull the pins out of the old plug and swap it over, turns out the neo plug has slightly smaller pins :(
3 crimp joiners later and i was away, i think the old sensor was ok but for ~$70 it should help on the way back up to qld
Installed my Walbro 250 pump in my M35 today and set up a power source direct from the battery to ensure full power to the pump at all times.
Reason for changing the pump was following the introduction of Nismo ECU, 3 inch suction pipe and spring on turbo actuator was seeing AFR being too high.
AFR's on medium throttle and below 4500rpm were all good and around 11.8-12.5 but higher rpm and more throttle saw AFR's is 13's.
So new pump fitted and now AFR's are much better at 10.7 to redline.
Now to start playing with boost again to see what the car will handle.
:rolleyes:
:rolleyes:
Hey Andy, that's a big change. Are the AFR's that rich throughout, or mainly heading towards redline?
Have to do a bit more testing to be sure but I don't think they were. Will be able to tell you more tomorrow.
Also got to get the boost controller working again and run more like 17psi.
Nice result & keen to hear what the AFRs are like after running around for a while. Mmm, more boost :thumbsup:
AFR's are
off boost low RPM (0-2500) 13.5 - 14.5
Low boost mid RPM (2500-4500, up to 10psi) 12.3-12.8
High boost full throttle (4500 +, 15psi) 10.7-11.2
Quite happy with these numbers.
Andy, those AFR numbers are pretty darn good. Off boost & mid range is very close to what I'm running. Upper end of rev range / max boost is a little rich compared to what I found works best for my car, so you have a nice buffer to increase boost safely.
Did you get a look at max injector duty cycle now?
I knew someone would ask that...... lol
It is certainly better than on the stock pump but at redline I am getting up to 95% duty cycle but this is with AFR of 10.5 so not too worried about that.
    • It's actually really good advice. And I do try to do it. I actually have 2x 3KG dumbbells that sit right beside where I sit. And I look at them a lot. Use them a little. But I'm trying to do more with it. At the moment I'm going through a heap of weight loss too which will help. I cracked into the 85kg mark this week. My weight used to have me sit consistently between 93 to 95KG! That definitely doesn't help. I've also got POTS, which flared up after I got slapped with COVID a few weeks back, and POTS really smashes fatigue and stuff into you, and has a thing even called "excercise fatigue". Basically even the minorest "excercise" (walking from the garage to the house) causes fatigue! And one of the treatments (Other than a med I'm on) is also... Excercise... Ha ha ha So it's why I'm trying to play the game of "might as well" and trying to push through things. For ADHD specifically, the general recommendation is "excercise". When you dig deep into it though, while any excercise is good, the best type is "explosive" excercise. So training for a sport like squash, tennis, even soccer. Things where you need to get the whole body able to "explode" into a different direction change. They've found with explosive sports, (I can't think of the proper term they have for it) that it actually makes the brain grow and become bigger in specific areas. The areas where ADHD causes those parts of the brain to be smaller than normal! But definitely, trying to push myself, and break those bounds mate, and get healthier!
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
