Lots of goodies arrived yesterday. HKS Fcon and harness, bonnet struts (thanks Cam!) and Deatschwerks pump.
I had one issue with the bonnet strut installation - bit hard to install when someone steals your drill! And here I thought everything was included... :nyaanyaa:
One question to people who've installed a fuel pump, Walbro etc: Do you buy a wiring kit or do you just go to Jaycar and buy all the bits outlined in the million and one how to guides?
Still need to order a fuel filter before I install it, and talk to the tuner about injectors. And settle on a tuner, I still have a couple of options.
Trying to run the deatschwerks on the stock wiring will end in tears, they draw way too much current for something so small and will definitely require a 30 amp relay and thick wiring at a minimum. I got mine from Jacar, I think it was a 60 amp relay with thick gauge audio power wire, run along the passenger side and under the back seat. Make sure you fuse it well and preferably run an earth from the battery too.
The old pump positive will need to be run the same way back to the relay in the enginge bay to turn the new pump on/off.
It seems the DW 1000cc injectors dont have the locking clips to hold them on to the rail, not sure I would trust that personally as all the other aftermarket injectors I have seen use them, even though their install docs say otherwise.
http://www.skylinesaustralia.com/forums/topic/383976-real-time-help-needed-dw950-injectors/
I replaced all the rear wheel studs and fitted the new shoes to the Stagea today.
BB5 LM 19 x 9.5 +25. 235/35 tyre.
Looks sweet.
Can I ask, are your guards rolled, do they scrub at that height?
Looking at (when i sell my Pupra anyway)19x9.5s at around +15-+20 but that offset looks pretty spont on....
I assume you have a manual too.
Also Sika'd my side skirt brackets properly today....
I thought it came with the plug and some wire and you just cut and shunt it
You can, but looking at the flow graphs you get much more flow at the higher voltage. Seems like all aftermarket pumps are recommended to be hard wired.
Bob, there are a few people doing hard wiring kits, including Deatschwerks and Aeromotive.
I did see that. Interesting. My tuner doesn't seem to care, as long as he gets the latency info, which will save a heap of time. Leaning towards the ID1000s, just looking at pricing.
Are the Bosch EV14 1000cc injectors the same as the ID1000s? I've seen a couple of sites referring to them as "Bosch ID1000" or "Bosch EV14 ID1000".
Also are you running the 11mm or 14mm ID1000s? And which length (48mm or 60mm)?
Yeh the ID's are just flow matched Bosch ones with a little machining to the pintle end, nothing special, so are the Xspurts. I think they are the shorter ones at 48mm.
I would rather buy from the Aust distributor, Injectors online just for the warranty. They will also price match to some extent.
So we have had this stagea for about 5 years now and have never posted it here hehe it has been a great car for my wife, it is her daily driver and had minimal dramas. It is a 99 RS rwd auto yer baby :-)
Ok so my wife and I just had our first baby so while she could not drive I decided to give the old girl a birthday.
I fitted some BC V1 coil overs, new tie rod ends, new front pads, a service, replaced the leaking inlet cam lip seal and fitted a Thule luggage box for holidays. I know it's not as racy as some on here but this car serves us well and it is now kited out ready for another holiday.
'Bout bloody time you post in here, Ryan. I've always wanted to know what your car looked like.
I called up my local Nissan dealer today for some pricing.
Fuel filter at trade was $35. I thought that was ok.
Ball joints I wasn't prepared for. Nissan wouldn't sell me the ball joints on their own, I had to buy a spindle. FOR $806 PER SIDE! $1600 FOR BALL JOINTS?!?!
So I'll be ordering them from ebay shortly, where they're around $62 for a pair. Thanks to Dale for his help in confirming the 350Z/V35 ones will fit.
On the plus side, at least Main North Nissan would look up parts for an import. I was all ready to ask for 350Z bits and started with the import bit just in case. Looked it up, easy!
Those guys are legends. The fact that you can walk in say "M35 Stagea" and they know what you're on about is pretty cool. :thumbsup:
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
