glad i got the money for it already
Bent sill; that's a write off for sure.confused.gif What did he hit?
And they wonder why P platers get such a bad wrap...
Got t boned reversing into his driveway I'm told???
So he was at fault too? Great...
Oh and btw you can have a lift with me if you ever get nostalgic for a Stag cruise. Unless of course you decide to upgrade to an M35 and drive yourself instead?
If I get that nostalgic, I'd rather go in a good c34 stagea :P
Thanks for the offer tho, but I'm over cars for today at least. New rig got defected today, right when I need it to tow the boat (an actual boat tho, not an m35)
Aren't they shit? There's always one floating around on YAJ...
Nope, you're thinking Gzone and thats more of an advertisement than a specific ECU you could buy. With the GZone if you win the auction you send them your ECU to remap etc.
This KSRom was a pretuned ECU for someone with light mods, exhaust and air filter by my reading. Also had rev limiter lifted to 7k and 1.1 bar boost. for ~$340 AUD + commission + shipping, not a bad deal at all!
Big Fella, sorry to see what happened to your old car. Was a great looking rig.
I've never heard of the KSRom. I'm assuming it's for the M35's?
Last night an intercooler felling into the front of my car. I had to fiddle it a bit to fit with stock engine bay piping. It's a Blitz LM Type J kit. Nice bit of gear.
Here's a few pics.
what did you get defected for?
RHD conversion needs SA engineers certificates. It seems our transport governing body don't trust Victorian engineers :(
All good, just more money that was gonna be spent on mods.
http://www.whiteline.com.au/docs/bulletins/Update%20BL-385.pdf
I'll be fitting them shortly and putting up a bit of a review. Whiteline have a few new parts in the works for the V35/350Z/NM35.
Cheers, Dale
Here's a few pics.
That looks rather sexy
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
