That's great news Craig. I hope you work out the CAS issue soon & get back up to full power. No problems maxing out the standard injectors? I reckon they are highly under rated, especially if you've increased the flow via better pump or FPR.
even better new Leon......Problem is solved.....I now have CAS!
Car goes like stink again!......it's very neutral in balance........power is just right!
I bet thats a relief! Great work.
Are we allowed to ask what the problem was? :)
Mate, that is great news. Btw, that stink would be left from your last passenger. I recommend a steam clean.
It was fixed by cutting the top off a zip tie and using it as a shim on the CAS.........so in other words I had to change the angle of the CAS slightly. f**k I wish I had the money back that I had thrown at this problem. I think every expert that I know or Dad knows has either had a look at the car or tried to diagnose it. Alex and I found the problem because I decided to test my spare CAS's before biting the bullet and buying another brand new one and when changing them back and forth this time I found inconsistencies in the RPM missfire and startup....so I fiddled and applied pressure in different directions and it either killed it , cleared it or f#$ked up the idle.....at first I thought the plug was stuffed but it seems that when we had done the GB change the CAS location has changed ever so slightly.....I dont' know how either it does not make sense!
Funniest thing is one or 2 of the workshops decided to call me and Forums a waist of time and we don't know anything.
I have a small quote for them!
"IN YOU FACE MR MECHANIC!"
Craig Markland
I might just point this out to them those workshops as well!
Happy days to......onto the next part of the project!....ECU's again!
Craig Markland
So time to do a drag strip meet to put a time on all our mods... :)
I think SO!....I still need to get the new Box in, Change spark plugs and do an oil change first.
Plus fit new bitsph34r.gif.....wont be cracking a mid 12 second past as I don't have the E-Manage on anymore but I should get a low 13 second pass!....still not bad for a 2 tonne fat cow!
Edited by Jetwreck
.... but I should get a low 13 second pass!....still not bad for a 2 tonne fat cow!....running stock injectors.....on pump fuel
edited your post for more drama, lol
I drove another M35 last night that does 14.4's..........I know my car is a lot quicker than that so it should be very interesting....at 18-19PSI my AFR's are at 10.8 so it's still got more in it except the AFM is stopping it....needs to be clamped somehow!
Good to hear you got it sorted, bastard it was one of those seemingly intangible fixes (cable tie? Really??)
ECU's? I can help you out with that :)
Edited by iamhe77
Jaycar have fuel cut defeater kit that I used on my last 33. It was only $20 or so to build. It has a trim pot so you can turn the cut of voltage right down.
How do you add fuel to the map with the voltage clamped so low? It's not a set figure, it changes with revs/load compared to what the ecu is expecting.
I agree. If it does clamp the AFM signal to 3.9V, the ECU won't add enough fuel under highish load IMO. My car reaches 3.9V long before WOT. Nothing wrong with modifying the AFM voltage, but to run nice it needs to vary under all the conditions the ECU is looking at.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
