Replaced the AFM this morning, and she roars into life!
I don't know what kind of Nissan engineer thought it needed security bolts... guess its so they can sell the whole tube.
Also the part number I received ended in 61A, not 611, for other people's info.
61A? hmm did it have the temerature sensor in the unit? and 5 pins on the plug?
I'll be in this; it's high time I got back for a comparison to my bone stock 14.9 sec quarter over a year ago.
hoping for close to 14.0-14.1.... :)
Looked the same bar a couple of markings. Diode on the outside. 5 pins. Works like a charm.
Only recently got my Stag. Traded it for my old 180 track/street car.
Came with some fugly looking rims so picked up these CR's and also got the NA grill to put on next and tinted the front windows to match the rear tint.
Fitted a new Pioneer 7300BT head unit yesterday, sounds good, will sound even better once I get my amp & speakers in. Getting the old tape deck out was certainly a challenge.
I seem to have a screw left over from somewhere, that's fast becoming my DIY signature whistling.gif
A bit sad for Christmas day, but the outlaws were over for lunch so, to ensure my day wasn't a total fail, I changed the oil.
lol .... if only it wasn't raining I would be doing the same.
Had a look at doing the wire snip, because I've been slack and haven't it yet.
Are you guys just cutting back the covering on the ECU harness and cutting the pink wire with the blue line?
Its not as if you can cut pin 55 directly...
Im just going to cut it in the morning then wire up a switch later in the week.
Tbh....I only really. Priced a difference when doing a stall and launch....but then again I have awesome and another.
i had some grey CR-Kais on my silver series 1 they look great. :thumbsup:
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
