Im running Aarons old Turbosmart compact, with the stiff spring it still runs fine. I only changed as the stock one wasnt coping too well at over 30psi, even with the grub screw mod.
How is my stock one going Jase? Prince Skyline had the same farting problem so I gave him my stock one to try. Seems to be a common problem.
Got the cruise sorted, finally! Works great, thanks to Leon for sorting and all the help. Probably just need to turn the gain down at some point I think.
Also got the other fog light switched over to spotlight with HID. Looks great, and very happy to have matching lights again. Looks much better matching. Was thinking about adding squid rings to fill the gap between old and the smaller new lights, but can't find anything with the right ID. Don't think it matters for now.
Next project is fuel pump while I wait for the SuperPro bushes and camber bolts to turn up.
Can't wait to get a wheel alignment - pulled one of the rears off on the weekend and the inside edge is all feathered. New wheels and tyres go on as soon as it's been aligned! :banana:
Took some shots of the spotlights tonight, just as it started to get dark. :thumbsup:
I actually like them now, I think I prefer the slightly smaller lights.
You can see I still need to finish cleaning the silicon...
Lights on!
For those interested, the lights are Narva 100mm spotlights with a HID conversion kit I got on ebay. Pretty easy to mount in the end, you just have to remove the Cibie glass so you can reuse the mounting hardware. Narva lights were ~$70 for the pair, and the H3 HID kit was ~$35.
My only issue now, as per the other thread, is Nissan don't allow the fog lights and high beams to be on at the same time. So according to Iain I need to wire up a diode and relay to fix this. Can go on the list!
They look great when on Ryan - nice job. I'm tempted to convert mine. Do they throw out a decent beam?
I can't think of the last time I actually used mine as fog lights, but Murphys' Law states that as soon as I change them I will need to travel a long distance in the worst fog in living memory.
Not yet - still have to work it out. Iain thinks he knows, I'll see if I can work it out.
I did this for a set of foggies on a Liberty years ago. I had a 2 position switch that allowed me to either a) lock them on, regardless of headlight position, or b) have them turn on & off with high beam.
That made them a practical addition. What would annoy you, & oncoming traffic lol, is if you had to dip head lights & also turn of the driving lights as a separate action. I'd be happy to play around & help out with a circuit.
Seem to Leon, but I haven't had a chance to try it out in the dark yet. Will do so this week. A single was great though, much better than the foggies.
That was my logic too... too hard to find a new fog light, and I never used the foggies. Spotlights are much more practical.
If you can figure out a circuit, that'd be great. It's not that high on my list at the moment, but the switch idea appeals.
Use the high beam 12v+ at the light and run that to a relay. So that when you turn the head liht on the relay will turn on. Then on the contact run a new circuit from battery (fused) and to a on/off switch and then through the relay contact and then to spotties.
So the spotties will only work when on high beam and then you can turn them on or off via the switch. Even if you leave the switch on the spotties will still turn off when on low beam via the relay.
That's all good, except if you want to run the spotties without high beam (or any head lights). That's why I previously used a 2 position switch, with the other position simply operating another relay to turn them on constantly. Of course that was before everyone started running with fog/driving lights on during the day & the police started cracking down on such use. To keep it nice & legal, maybe best to stick with only on when on high beam....
On the weekend I checked over my adjustable arms (camber/traction) and dropped the suspension 2cm allround. May drop it further, but will do a week of driving and go from there.
post-58831-0-06660300-1329199764_thumb.jpg post-58831-0-38074800-1329199802_thumb.jpg
Also removed the rear wing and debadged the boot.
Fitted Blitz LM panel air filter... :blush: The old K&N looked horrible.. After serving good time in the R33 and now the M35, time for a clean and maybe retirement...
Thanks Jason :thumbsup:
RDA slotted discs and HPX pads go in on Friday as the old girl gets serviced... Looking forward to non-shuddery brakes...
Out of curiosity, what did that set you back?
ask boostin imports in the trade section, they've usually got pretty good prices. mine were 799 for all 4 (different car though)
Replaced the bottom headlight bulbs, but now going to look into what the top ones are. Tomorrow aiming to get the new LED parkers in, and hopefully run the wiring for the new fuel pump, if not get it all finished.
Got in it today though to find the air con blowing hot air for the first time, and three of the four windows won't go down. I think the thermo fan is buggered.
Also picked up a small trans cooler today to use as the power steering cooler. Think it will be ok, hopefully won't be too small.
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
