bought some yellow paint from supercheap (guessed the colour) and finally painted the rust under the mirrors and the knock on the front bumper
just loading it up atm for the trip to tassie on sunday :)
to the guys with the heat shielding, round the corners on the sheets and they will be less likely to peel off
Fitted some single piece braided brake lines to the front today, big thanks to Chuckie for the help (sourcing and fitting) :thumbsup:
What a difference! Already had slotted RDA 350Z rotors, EBC greenstuff pads and a master cylinder stopped so while it doesn't stop as well as my 32, it does pretty damn well for a bus. The braided lines have improved braking response tremendously, instant bite!
started installing the black interior! did 4 doors, the top half of the boot and the lower half of the dash. its gonna look good in black :)
lol my sister wrote her car off yesterday(well i hope it is) im gonna take her black V35 interior i might buy it back lol
Had a leak in the dump pipe repaired.
Polished the cam covers.
Polished the crossover pipe.
Replaced all the turbo manifold gaskets.
Inspected the turbo while it was off and its still in good nick.
:thumbsup:
which paint did you go for, how faded is your paint and how was the match?
Got a bit on mine i need to fix up
its ok, mine was for under the mirrors and a scrape on the bumper so was better than it was
will take some pics but i won't be able to get them up for a while
GB Swaybars went on yesterday- before it got stupid hot in Sydney. Back was easy, Front-one prick nut was putting up a fight. Rear sensor had to be re-aligned to fit because of the adjustable bits on the bar. Other than that, all smooth and good! Great improvement when driving. Will drive more :woot:
On the LHS rear sway I think they added some sort of roll sensor. Its a Bosch unit, that measures body roll via the bar movement. Can only think it does something for the AWD system, as there is no stability control. Maybe ABS...?
pity they didn't strengthen the rear mounts... I've got the same ones as everyone else. >_<
I replaced a sidelight this morning from the top. removed the airbox etc etc... very enjoyable. Hope it doesn't go again anytime soon- could they have found a harder to get to place?
now dump it! :P
First I have to pull some camber out of the rear as it's eatting tyres silly fast. Also have to get some springs made up for the front so I can drop it and keep the spring rate I want. I'm also needing some front camber arms and some SA spec bolt-ons..... :rofl2:
Then dropped :D
Made it to tamworth
The rad flush I did had moved all the crap about and the I think the rad is blocked, saw 111°c on the ecutalk display and had to start using the heater to cool it down :(
38°c out side and the heater on full = fail, just 1300 kms to go, temps are between 80 and 95 now, just don't have time to get it sorted cos we are tight on time :-(
We'll get there tho
111c wow thats not good at all :S hope you didn't cook anything mate
yeah it works out which way the car is turning and how much power to direct to the front wheels
i wonder if you can spin the rears or get it sideways easier now as the car will sit flatter? or maybe it will be worse?
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
