This is what I'm aiming for, what's your setup?
Autech 260RS
Stock bottom end
Stock FPR
R34 GTR turbos < Terry's old turbos :whistling:
Nismo 555cc injectors,
Walbro fuel pump
Power FC
AVCR
Z32s
Greddy suction kit and cold air box with factory snorkel
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Yoshida Garage custom ported head and port matched exhaust manifolds
Greddy extended split dumps and front pipe
Fujitsubo Cat back
Gutted cat
N1 oil and water pumps
Greddy oil cooler kit
Turbosmart BOVs
312.5kW at 16.5 psi
272kW at 13 psi
yep, the jaycar kit, works perfectly. Just tapped the speedo wire at the dash and hid the box up behind the hazard light switch. It's been in there a while bu I had to adjust it because I've changed rim/tyre size recently.
Nismo dash is the main reason I had to fix the speedo. A big digital speedo is just annoying when it's wrong!
Drunkan, you've fixed the speedo, but the tacho looks like the reading is out of whack too. And what wheels and tyres are you running now? Pics please?
Oil change (my last bottle of GW Sougi s6000), and a yearly inspection of the turbo oil feed banjo. Was enlarged to 1.5mm last year.
Looks like I'll be changing to the new GW SYN-X 6000 for the next one.
I checked my banjo this week and it was squeaky clean. I didn't enlarge the size of it though.
Edited by slippylotion
Whether or not to enlarge seems to be a personal thing; to each his own. There's no question; it's cheap insurance to remove & inspect.thumbsup.gif
Autech 260RS
Stock bottom end
Stock FPR
Walbro fuel pump
Power FC
AVCR
Z32s
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Fujitsubo Cat back
Gutted cat
Turbosmart BOVs
312.5kW at 16.5 psi
272kW at 13 psi
Nice Build, bet its great to drive
I was just wondering how the Power FC goes with the 260RS, Im assuming you used the one specific for the R33 GTR/RB26
Did you have any issues getting it to work, does anything not work as its meant to.
from what i have read it "should" work fine in the stag but i have not asked anyone who has actually done it,
Thanks
Thanks
No problems here
Yeah mate that tacho is wierd....lucky mid 90s LCDs had such crap resolution. It consistently reads 500rpm high, not like the speedo that was a % wrong (ie wronger the faster you go)
I've got R34 GTR rims (finally clearning the brakes properly) and 255/40/18 Federals. No pics it's too wet :P
Also fit Z32 AFM today, total fail. SOmeone has played silly buggers with the Z32 AFM curve on my Powerfc and it's not running properly. I'll probably put the standard AFM back on until I can get a tune.
Thanks
I am running a R32 GTR PowerFC and the car runs fine, an R33 PowerFC would also work.
I Run a R33 PFC (on a R33 RB26) with almost identical setup, minus the inlet and hard piping kit, but I'm still around 20kw short of your power. Guess its time to order those Z32s and the Greddy kit then... thumbsup.gif Good to see whats possible with stock bottom end and turbos...
Found a little cubby hole for a oil catch can today. Hopefully will minimise the amount of oil going out the end of these bloody VQ's. Have to go to pirtek tomorrow and get some real hose- as usual the stuff they give you is massively shit.
you need one from an RS with hicas, or an ARX. but only vq25det
Not true. Pretty sure Craig said 350Z 5MT rear diff, but I'd have to check.
I think the VQ25DD front diff is the good one though, haven't double checked yet.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
