Not true. Pretty sure Craig said 350Z 5MT rear diff, but I'd have to check.
I think the VQ25DD front diff is the good one though, haven't double checked yet.
The 350z manual lsd is the one I run too, different ratio so you will need to source a PM front diff in the same 3.5:1 ratio.
Oh, 5 speed. Ok. Yeah couple of people have gone to 3.5 finals now. Seem happy. Don't know about the cost benefit of it compared to other mods, as the two cars with it done are probably the most modified in the world!
The car feels much more responsive with the lower ratios, it gets the slug moving quicker but the downside is cruising on the freeway at 2,500 revs. Just what I need, less K's to a tank... :rolleyes:
you should have more k's..........less load!
On the fwy i'm in -boost simply because I am not riding the torque converted right down low at 2,000rpm anymore(it used to be +boost).......I am pretty sure I was 10.2lts per 100km's on the way home from Vic the other day fully ladden.
What? Have you read what was posted at all? :)
You can just drop an ARX diff in, no need to change the front one as the ratios are the same.
If you go for the 350z LSD you will need a PM front diff or as Slippy found, a 2.5dd front diff may be the same 3.5:1 ratio.
LOL....my bad!
New rotors, pads, coilovers, coils & plugs, o2 sensors, dash & floor mats, 4700k high beams, personalised plates, alarm installed, front windows tinted, all fluids replaced, and a new tune:)
Should keep her happy for now...
What? Where? How?
cannot tell....I am sure the gaylord will post sooon!
I can say the chase is on again!
E-Manage and injectors WILL go back in mine tomorrow.
Edited by Jetwreck
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
