The Stagea made 335 rwkw at 25 psi last night with the new sound control exhaust. Very interesting to drive now, especially in rear drive. :cheers:
Well done Scotty. And I mean it ( you know when people say well done to someone just paying $, insted of actually building the car-like you have!)
Interesting final figure. I heard 328 @ 20psi from you know who last night.
Do you think that there is a restriction- as 5 extra psi didn't net much gain. Have you found the limit of the stock manifolds? Its not the Exhaust...
Or on the other hand, was it made a bit safer in the tune?
Dyno graphs please!:thumbsup:
Nice work Scotty! You've got a lot to be proud of with the development of your car.:worship:
Must be a hell of a thing to drive now!:thumbsup:
E-manage back in and running
One last tune......I wont catch the Scott's figure.....but hopefully will crack the 300AWKW's!
Craig, you sticking for 98 for 300kw, or switching to E85?
Scotty, great figures. Since it was measured in RWD, is it likely to drop when you get that front diff in, in terms of awkw?
sticking with BP98......cannot be bothered with E85.....I should have more than enough power for what I need or want.
I'm not really aiming 300AWKW's.......250AWKW's should be more than enough for what I want.
Took my car to Hampton Downs yesterday - best lap of 1.24.22 with 240kw.
Hopefully will have around 300kw next time.
Anyone who hasn't tried a track day should give it a go - great fun to be had hammering it flat out without fears for your licence!
A brake service with front discs machined and new pads all round..
Give the car a good clean and my much loved car will be for sale. :(
stay tuned for sale listing.
Are you getting a Series2 ready for the English conversion
Fitted Whiteline camber bushes a few years ago now due to the usual rear tyre wear issues. Was still chopping out rear inner tread (though not so bad as initially) so I have now fitted aftermarket rear adjustable links (upper) which should solve the problem permanently. One small hiccup in the process of removing OEM camber links, only the outter camber bush had been adjusted. The inner bush was set at (nothing, not used, set at minimum) :angry: What I don't get is that the knuckle heads that did the alignment fitted the bushes so it was not as if they were unaware of full adjustment facility.
Oh well, onwards & upwards now :turned:
GW :miner:
After nearly 2 years of owning the stag i finally connected the automatic headlight adjustment plug... the retard compliance guys filled the plug with silicon when they removed the HID lights.... does anybody else use this fearure?? Its a S2 by the way
I finally got around to fitting the radiator fan shroud, not much left of the radiator mounting side as the radiator core is so big. Also re-installed the Mishimoto 62 degree thermostat while I was there. Hopefully no more overheating issues in traffic.
Automatic headlight adjustment? Mine just has an adjuster switch so I can set them as high or low as I want.
Yeah thats what im referring to... its automatic opposed to popping the bonnet and adjusting with a screwdriver :)
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
