i didnt know your turbo was on the way out leon, damn!
dont bother with new arms, just replace the bushes. unless you want stock bushings, then i have a pair of arms :P
Yeah, I was hoping it would hang around a bit longer. I think if I didn't play around with it (read add boost etc), it'd still be going ok.
In the end I couldn't drive it without plumes of white smoke every time I lifted off. Funny, the cars got 99,xxx km's, and everyone said to factor in a turbo change at 100k, lol. Was planning to prove everyone wrong, but couldn't help myself - had to push it....
I have new bushes on the way courtesy of Dale. Arms look straight, just not located in right place.
Are you still going Hypergear rebuild Leon?
Did my final prep for the SAUSA track day today - replaced the oil and filter, fitted a power steering cooler and replaced the fluid.
Also noticed that I've got a set of semi slicks on the car - once the car was up on the hoist noticed the rears are almost on the tread bars, so will be replacing shortly.
Couple of things do to now, replace the drivers side inner CV boot and replace tyres (and upgrade to 18" wheels), before I get back to upgrades.
Well i have definitely proven everyone wrong. 305,000 klm's - stock turbo.
Ever since i got it @ 132,XXXklm's (previous owner did not rebuild the turbo), I put it straight to 12psi.
I have always done 10,000k oil/filter changes (motul 8100 excess / ryco filter) and i always make sure my last 5minutes of driving are tame and to leave the turbo timer running for 1 minute.
Seeing as my turbo is that ceramic/nylon mixture I am quite surprised. I bet i have now jinxed myself and tomorrow it will die...
Edited by Jezboosted
Yeah Ryan, Hypergear rebuild like sky^rkt, but not as wild as his. I hear he's aiming for a big number from the stock housing. Will be interesting to hear how it drives when finished. Mine should be almost as responsive as the stock one, but with a bit more puff up top & no puff out the exhaust, I hope.
Let us know how your track day turns out. Sounds like fun.
So I've modified and painted a Dayz bar.
Plastic Dayz bar with some previous damage. I removed the centre number plate bracket and recess the number plate in the front cover and painted it up. Came up ok but I rushed the colour coat and got some crap in it. Will have ot come off the car again to be fixed.
The bar when I fitted up the cooler.
Final mock up before glassing.
Progress and final before paint prep.
Painted and fitted
SAUSA track day today at Mallala.
First session was shit. Two offs, one due to tyres through turn two, and one when the Trans wouldn't shift down.
from there on it was awesome. Car was relatively trouble free, despite the shitty tyres. Brakes were awesome, but front wheels were covered in dust, rears clean.
Only real issue was the Trans. By the end of the day the 'manual' mode wouldn't shift down at all, but it was fine in Drive. I'm guessing shift kit and Trans cooler will fix this? Anyone with one, does it actually shift when you tell it?
I also had issues with the shitty GPS timing app I was using. Best time it recorded was 1:36.5, which doesn't seem too bad for a first attempt.
Tyres, shift kit and F-con before next time!
Not really, it wont kick down unless you are going slow enough, buggered if I know why as it will kick down when you least expect it on its own.
The shift kit makes the gear changes firmer but the stock ecu still backs out all the timing between gears. Fcon will fix that though. ;)
Turbo is out finally. Thanks to Scotty & Jetwreck for their occasional pearls of wisdom. Hypergear one hasn't shown up yet. Hopefully tomorrow so I can staert putting it together before I forget where eveything goes.
I can't believe there are people who do this more than once!
No problem Leon, not a job I would recommend people do themselves as you found out. lol. Just hope the mani studs stay tight on yours, Ive had a few come loose now without those copper coated nuts holding them tight. If not you will get the dreaded gasket squeal and have to do the job again. :no:
when they get sprayed and the rear wing and other bits are on the car I will post up pics of my NM35 N250R WB LM!
Received my F Con Harness today ;)
Also bought a bonnet today :whistling: Would probably look good on your car Craig....and it is already black!!!
Bastard!.....it would look good!!!! Would....lol!
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
