Finally fitted the new wheels and tyres!
The old ones were a bit knackered...
Although perhaps I could reuse them as semis?
New tyres are Hankook Ventus R-S3 245/40R18 XL, so they have a higher load rating.
Mounted on some new Braid Winrace A 18x8 +30s...
Front:
Rear:
The offset isn't too bad in the end:
post-34363-0-71778600-1339830557_thumb.jpg post-34363-0-67935300-1339830570_thumb.jpg
Also put on Volk Formula nuts, which seem to look good in combination.
All in all, pretty happy, and they're much nicer to drive!
Big thanks to SA Motorsport Tyres for a great deal, and a lot of help putting it all together. Looking forward to the next track day!
More pictures tomorrow after Moby has had a wash!
Looks the goods mate. If I were you, I'd find something a good detailer would recommend as a paint sealer or similar product, and get it on them right away. Will help get the grot off. There are some not so good products out I've heard, so consult a good detailer.
The old jap playz tyres hey, good for skids!
Thanks guys. Yeah the offset worked out well in the end. And they do look a lot like an old school race/rally wheel, which I like :D
I'm heading down to Autobarn tomorrow to get some proper wheel cleaning gear. The QFM pads are pretty low dust until you get to the track. Then the fronts just caked the wheels, backs not quite so bad. Dad has some great Wurth gear that you just spray on and soak in, then hit it with the hose (with some pressure).
Haven't heard of sealing them before, I'll look into it, thanks Alex.
Looks the goods there Ryan, you're running the same offset as mine, with a slightly smaller rolling diameter.
Regarding Wheel sealing; I definitely recommend it, I've been using Autoglym Wheel Seal for several years now; it's just an aerosol spray on; wipe off deal.
I re-apply it every few months, and the brake dust just washes away with a Meguiars wheel detailing brush.
I'd stay away from anything you need to leave soaking; they should clean up with minimal effort once sealed.
Less "What I have done" and more "What Alex has done".
Dropped off his Chassis Brace last night, and Alex kindly offered to throw his laptop & Cypher diagnostic on my Stag, to check for any outstanding ECU and SRS fault codes.
None found; which was not unexpected, as my Attessa works fine, and I don't get any random Airbag codes.
He then offered to throw 2 degrees (from a possible 3 deg advance in my case) of base timing in, and see what I thought of it. TBH, I wasn't really expecting much; but Alex told me a few interesting things about the improvement on another Forum members car.
A quick run up the street to ensure there was no knock; all good.
The trip home revealed a surprising result. The car is more responsive at small throttle openings, and seems to come on boost a little harder too. It's hard to explain; but it just feels a bit "tighter", like a bit (more) of the slack has been taken out of the throttle. Also it's less inclined to kick down on a hill in top gear, on the cruise control, which suggests that there's a bit of extra torque; just as Alex suggested
It's another little "1%" improvement, that our cars seem to have plenty of...
I'm quite impressed that such a small change could net such a pronounced improvement. I'll be giving it a bit during the week and if all is well; I think I'll be asking Alex to try the last degree at the Stagea meet.
Thanks again mate; when we were talking beers, I was honestly expecting a sixpack; not a whole case! :woot: I'll still drink them though...
Also pressed in a new set of Whiteline Lower Control Arm bushes, ready for my new brake set up this week.
Yer he did the same to mine, I find it's just a bit more responsive than normal, just a tad which helps with the shift kit:)
Yours was the car I was referring to Rudi; did you go 2 degrees or 3?
Every time I have a little tinker; I find myself wanting to spend buckets of money...
Dale, I'm glad your happy with it!
No worries about the beers - thanks for getting me out of that sticky situation.
Very happy mate. :yes: Bring your laptop next weekend please? I think I'd like to try that last degree.
Any time mate; happy to help out. Drilling holes in other peoples stuff, while partially drunk is my speciality...
Cheers Dale. Never sealed wheels, so I'll head down and see what I can get. Good call with the brush too, getting between those spokes could be a pain.
The Wurth stuff does a great job, never had any issues with it, but I'll probably give the Bowden's Own wheel clean a go. Really happy with the rest of their stuff, and have alook at that Autoglym sealer.
Good to hear the timing works. Keen on going an extra degree?
I put mine on a truck a few weeks ago and had it safely arrive in Perth on Friday.
I had a search but turned up donuts, can anyone recommend anyone to go to in perth, preferably the nth side to look after it? If they can do a vehicle safety check (pink slip) that'd be great too!
Now just waiting for my Apexi N1 from joshm35 to arrive :P
Edited by NickM91
Yeah, there's no sign of pinging that I can hear, so I figure if it goes well during the week; why not?
He did 2 degrees from memory. It was worth the try I think :)
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
