looks like im going to go for a highflow after all that. i talked to stao, and he suggested that if im not planning on going highmount in the future to make bigger numbers with the ATR43G3, then i might aswell highflow. as said above the extra 20 or so kw, is not worth it with the G3 when i can have the highflow with only slightly less response than standard, and being a heavier car the response is probably more benefical than the 20kw.
cheers for the help guys, looks like ive got it all sorted.
Edited by OMY31T
Just picked up the passenger side cam cover gasket to fit tomorrow. Came in just in time as yesterday I pulled up at a mates workshop and had smoke coming out from under the bonnet due to the oil running into the turbo!
If people want I can't do a DIY write up on how to do it for those wanting to have a go but aren't sure about how to go about it.
Edited by slippylotion
You might as well; it can't hurt to have one.
Maybe put it up on the "Awesome" forum too, Iain would be happy to have it there; that's the best spot for "How to's" IMO.
Not a problem. All we need is someone to do a turbo remove/refit to show the easiest way to go about.
I would but my hands are always too dirty, and the missus won't let me use the camera.
The way I do it involves a few special tools I have made, and also requires a fair tool kit (torx sockets, extra long extensions with universals, deep sockets etc,) not something I would generally recommend as DIY. Its a biach of a job.
Plenum off.
Rocker cover off (12mm bolts I think)
Remove rubber seal
install rubber seal in rocker cover
Get Fkd off trying to keep the damn seal in the cover whilst reinstalling lol
Bolt down rocker cover
Reinstall plenum etc
Look forward to reading your write up Paul and hearing how you go about keeping the seal in the cover when reinstalling :)
I could definitely fyp...
Plenum off.
Remove rubber seal
Start car and find the new gasket is leaking worse than before.
Do the whole job again...
FYP instead. :P
Or is it so you guys can keep offering your services for cash money to do the job for them? jokes
Feel free to come on over and help with mine; I'll stand back and take the pics...
I wouldn't want to get in the way. :whistling:
If your in Adelaide I would give you a hand.
Give me a chance to do the mistakes on yours before I did mine! Lol
dale are you doing yours at the workshop?
ill come take pics and give a hand if its a weekend im around
I hope so, if Craig is still speaking to me after the 11ty billion phone calls in the last week or so...
Fitted that insert yet?
What are you so worried about Paul, it's a simple turbo swap, and don't you have access to a hoist? Pictures in such a confined space will just confuse you more, it's not like you can see the bolts. Just give me a call when you do the job, i'm happy to work you through it...
No hoist access any more as he sold the business, so back to working on ramps :down:
Na Im not worried, just thought some tips to go about it as easy as possible would be good for me and others wanting to tackle it when the need arrises.
Hopefully it won't need doing for another year or more but who knows with these things, get ready for that call then!
Cheers
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
