I don't know if your mate is my mate (Chris from Craved Coatings), but he did the radiator, oil cooler and sump on my race car, it definately ran a degree or 2 cooler afterwards. When you are pushing everything super hard, every degree makes a difference.
Duncan, my mate is in Penrith also; but it's not Chris. I've seen the Powdercoating that Chris does & his work is amazing, my mate is only just getting in to the decorative coatings, and there's a few ceramics (the polished finish ones) he does that Chris can't do.
You're dead right though; at the limit, every little bit makes a difference, and there al all kinds of coatings, heat shedding, heat retention, heat reflecting, anti scuff, lubricant holding, lubricant shedding; the list goes on and on.
I'm really going to have to investigate these coatings more because I drive my nimble beast at the limit every time I take it out.
LOL.
The creaking and clunking tune it makes now is horrible. Seems everything is coming at once ATM. Attesa pump, cam cover seal and piano bushes. That's three so hopefully good for a bit now ?
Edited by slippylotion
Update; Turbo is out now. :banana:
post-61153-0-47778500-1343300106_thumb.jpg post-61153-0-45897300-1343300163_thumb.jpg
Truly there has never been a better example of the right tools for the job than this job.
After wasting hours yesterday with the heatshield bolts; we bought two Snap On spanners and a 3/8 drive 10mm single hex socket. What couldn't be achieved in several hours; removing the heatshield was completed in around 20 minutes. This cleared the way to finally free the turbo from its home.
I've also modified the offending heatshield so that the remaining section can be refitted; all the bolts can now be accessed, and it can be completely removed in about 2 mins.
In other news, the exhaust housing, dump and mid pipe have now been blasted, baked, blasted again, and coated in the thermal basecoat.
It has now been baked out and is cooling. The external thermal coating will be going on tomorrow, with the internal coating for the exhaust housing and dump to follow.
post-61153-0-82551900-1343300963_thumb.jpgpost-61153-0-60004400-1343300888_thumb.jpgpost-61153-0-53352900-1343300874_thumb.jpg
The coating goes on a greeny colour as seen on the Dump & Mid pipe; then dries almost white, as seen on the exhaust housing.
Once baked; they are almost completely white.
Edited by Daleo
I can get some numbers for you tomorrow; they're about $55 each though. I'm planning to marry mine.
I didn't take a pic of the heatshield, but I'll get one tomorrow.
Sweet, thanks. Should start getting the tool kit in order for when the inevitable happens.
What is the gap like on the rear wheel from the housing? It looks to have huge clearance, is it just the photo?
That's only a baby turbine, should be responsive. Good choice buddy. :)
My special tools... Cost : $0 ;)
The clearance is reasonably tight; I think it's just the pic, there's a couple of funny reflections & shadows. The coating will close the clearance down slightly too.
I'm hoping so; we'll see in a few days.
Trust me; if the Snap On truck hadn't been in the corner, we'd have been doing the same. I already had one long spanner made up.
Paul, I took some measurements today, but I left everything at the workshop.
I forgot to mention, I received these springs in the mail today, should hold the gate shut till around 26 - 30 psi. :)
Install tomorrow along with the thermo fan controller.
Anyone for a 3.5 inch dump?
And the new torque converter, packing triple Pathfinder lockup clutches. Not sure when I will get time to drop the gearbox again...
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
