m35 owners need moar manual, then it may get easier
Meh, aint going to happen any time soon unless you want rwd skids, there is nothing wrong with the auto anyway. Why do you want easy? I like the challenge.
When the m35 ecu is 20 years old and has years of motorsport development behind it we may have more aftermarket ecu options. Until then, what's wrong with the Fcon Vpro?
You like the challenge because no more aus post lol. Lucky f**k
D'oh! Blocked Cat on the dyno, and boost actuators are too small! Cat was causing 8psi backpressure, apparently.
So.... New HKS actuators being fitted first thing tomorrow, cat to be freed up, and back we go to the dyno... Can't help but shudder when I try to calculate what the bill is going to be this time around: one thing has necessitated another, which has necessitated another etc etc you get the picture... :(
Well it looks like I wont be taking the Stagea to SuperFap. Couldn't get Tie Rod ends for it in time. No one in NSW/QLD had factory or aftermarket stock. Have 2 on order from Nissan Aus, but wont arrive until tomorrow.
Gotta take the wife's car instead.
we're talking 260rs's here
so i assumed he had a tuneable ecu already seeing as he made 270kw already
yep i have a nistune
You wanna talk bills get a 260rs
i just did a full rebuild,bought some second hand gtss and one has now let go :wacko: now im doing what i should of done the first place :domokun: a singel turbo conversion that bill is $5,000.All this after just buying my first unit im sure up s@#%t creek without a paddle :whistling:
Edited by R33huntme
Finally, the pics of my suction pipe.
Firstly, excuse the first pic; this is not the usual standard of my welding. Issues with the TIG at my mates workshop, resulted in oxidised weld beads, and I ended up having to MIG the Blow Off return into position. Internally the pipe was purged, so it's immaculate.
Pics of the pipe after coating; the ugly welds are not visible; but I still know they're there...
post-61153-0-67699200-1344431863_thumb.jpgpost-61153-0-80967900-1344431892_thumb.jpgpost-61153-0-54284600-1344431925_thumb.jpg
The two pipes side by side; doesn't really give much of an idea how much larger internally, and better flowing the new one is; because externally, they're almost the same size.
And in it's new home; possibly never to be seen again...
No comparison times as yet, but I'm very pleased with the end result, and it sounds great coming on boost now.
Nice Dale :thumbsup:
I see you didn't manage to extend the top bolt thru so it can be done up from the front, like the oem intake. I doubt it is possible actually, because of the larger pipe. But it's such a hassle getting onto that bolt..
Edited by Commsman
Looks good Dale, any idea what the ceramic coat would cost?
Cheers mate, I can find out & get back to you.
I didn't, because I ended up just using a socket headed M8 bolt. The way I oriented the pipe; it's possible, and fairly easy to locate & tighten the bolt with a ball end allen key. I just hook a small spanner over the short end of the allen key to tighten it at the end.
I had the pipe on & off several times (was a bit tired & forgot to reconnect the water lines) and it's pretty easy to access, but if I was to make another, I'd index the bend a little lower to give a bit straighter shot at the bolt.
i just did a full rebuild,bought some second hand gtss and one has now let go :wacko: now im doing what i should of done the first place :domokun: a singel turbo conversion that bill is $5,000.All this after Ijust buying my first unit im sure up s@#%t creek without a paddle :whistling:
I hear you: Mine's a conversion from RSfour. I know the wallet pain of an RB26 all too well...
That said, it's been worth every cent so far!
Looking at picking it up on the weekend hopefully.
Last tune before these shenannigans was 420hp @wheels. First time with all the new gear was 409hp but with less boost due to the enormous back pressure. Hopefully I'll gain a little top end, but I'm hoping for much earlier spool and a dirty bug chunk of midrange torque this time around.
Fingers crossed... ;)
Awesome work Dale.
Is that 2.5" pipe?
Now I know whats holding up the front braces! :P
Yeah, 2.5" mandrel bends. Much smoother inside than the factory piece.
Lol, a bit; it was mostly having no car and having to ride everywhere that's been the biggest delay.
They'll be going out early next week.
No worries, all good!
Is everyone making them out of 2.5"? Might make it easier with mine, just have to change the bottom half (perhaps even from your new production run? :whistling: ) and I can keep my 2.5" -> 3" second half...
The bottom one is the hard one imo.
The bottom one is the easiest for me. My top bolt needs a ground down spanner & each time I get 1/8th of a turn, plus I rip my forearm up as I jam it down in there.
Now that sounds cleverer than my standard hex head bolt. I may look into a better method, but each time I put it back I tell myself not to bother since that will be the last time I need to remove/replace it. Must have doen it more than 10 times so far & it needs to come off one more time (redo turbo oil line). But this will be the last time, lol.
2.5 inch should be good to around 240-250kw, for anything more 3 inch would be required imo.
And that should suit 90% of people on here. Production run....?
Edited by Commsman
Hey Leon, I have some good news regarding your oil leak mate; check PM's :D
I'm a little reluctant, as I will not take money out of Scotty's pocket on this one. If Scotty is ok with it; I may look at it.
The other issue is as Scotty has said; this one will not support maximum power, and you'll need to start again if you want to shoot higher than the 240odd kW mark.
good luck let us know what you end up getting
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
