Australian Tax Office?
The only people that can help would be Fair Trading...
yep, you would be surprised when you there's dodgy dwellings going even if there's not , just mention the ato and Wamo:)
Fitted the temp controller I bought from Scotty this arvo; after a bit of rewiring, I now have fan control.
Also threw my rear brace on ; but haven't driven far enough to feel the difference yet.
So it all works fine? Good to hear Dale. :)
I should fit mine...
Sure does mate, but not before I'd given it a good stern swearing at.
The good news is; the thermocouple appears pretty accurate.
I wanted to test it on it's lowest setting (70deg) and it still hadn't cut in at 85 deg; so I thought something was amiss.
Swore for a bit, then switched it off & had another go; the important bit was setting the dip switch to allow the dips to adjust; not the button.
Due to the clear, concise directions; I'm not sure how I missed that bit. :rolleyes:
Going to run it with the thermocouple on the rad and see how it performs; I may end up moving elsewhere.
Stagea is going on the hoist tomorrow (thanks to Andrew at ASR Automotive in Castle Hill for making some room for me to enjoy my day off) for a wheel rotation, plugs, oil + filter, fuel filter and drop the front driveshaft. Meanwhile the ECU is coming out while the Nistune is reflashed with a manual image...thanks to the original supplier I have an auto image and it is anyone's guess whether that has been causing some issues with boost cut, throttle recovery, cold/hot start and few other niggles??
Then Saturday up to DVS-JEZ's dyno for a bit of a check of the tune. While up there I will try a different CAS, drop exhaust and play around with a few settings.
I had a little care package arrive yesterday from Iamhe77. 3" Nismo exhaust and Ox rear brace.. Will admit I am pretty happy so far. The car is a little quieter then i expected but i think once i change my dump and front pipe it should be just about perfect.
The OX bar seems to have made a little difference, Cant wait for the front now
My Legalis was pretty quite until I finished it off with a dump and de-cat front pipe :)
All went smoothly enough car has new fluids, plugs etc ready for some dyno time on Saturday.
Big thanks to MRC for removing the Nistune and flashing the manual image back onto the board. Mark was kind enough to show me the full procedure from de-soldering and bridging the board to put the board into the correct mode to reprogram and then the reverse.
Glad you're happy Josh but I should mention again that 70mm is 2 3/4", not 3".
Missing my rear brace :( Guess I need to find somewhere down here that could make up a custom brace...
Just back from DVS-JEZ after tidying up the tune with the manual image. Great job by Jez sorting out all of the issues with the fat slug.
The drivability off the line is so much better with a few changes to the variable cam timing and a few tweaks with fuel and timing just off idle. Found a some more power by going a richer in the midrange to top end. It liked the extra cooling and made some solid power gains with a few more degrees timing.
More low? Maybe grab a set of Silk Roads?
SO....Scotty helped me fitted the SilkRoads Coilovers today...with the custom springs from SilkRoads (Previous ones were too low)
REsult: Now I can go bush bashing...fronts look good but rears are now ARX height, if not higher :S
Edited by ironpaw
So 80's hotrod spec with the arse in the air? Picsbeforeanglegrinder
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
